Finished - compact 3 DOF with traction loss
Discussion in 'DIY Motion Simulator Projects' started by Robdog, Jan 12, 2017.
  1. Robdog
    Robdog Member
    Newcastle, Australia
    104Coins
    3DOF, JRK
    I have a made a change to the mounting of the hall sensor. Previously it was mounted on the motor shaft but I was getting the odd spike in the signal which was annoying. I think the spike was caused by backlash in the gears and a little slop in the linkage all magnified by the length of the lever.
    The sensor now measures the position of the seat rather than the motor position and has completely eliminated those spikes. As a result I have been able to increase the sensitivity of the axis and am really happy with it, even if it looks a little weird.
    • Like Like x 5
  2. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    @Robdog , sorry for my noob question... if I understand well your traction loss doesn't have a pivot point on front? Only one motor connected on back, right?
  3. Robdog
    Robdog Member
    104Coins
    3DOF, JRK
    There is a lazy susan bearing at the front under the pedals, the bearing is as wide as the frame so the frame does not rock from side to side. The movement is provided by the motor at the back.
  4. Remishka
    Remishka Member
    Musician, Woodturner
    39Coins
    You beast looks awesome congratulations ;) .
    I do have a question tho, what kind of reductors are those ?.
    Good day to you.
  5. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Very good work and design! Congratulations! regards...
  6. Slider
    Slider Active Member
    Irrigation
    Brisbane
    1,130Coins
    2DOF, JRK
    Really like your build, well done. I really want heave and traction loss but have to iron out other issues first.
  7. zgseat
    zgseat New Member
    Engineer
    Shanghai, China
    135Coins
    your rig is cool,like the compact design。
  8. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    299Coins
    Good design! I also have a compact seat mover, but only 2dof
  9. Robdog
    Robdog Member
    104Coins
    3DOF, JRK
    Thanks. It is worth the effort of adding a heave axis as the sim really seems to come alive when it is added. My traction loss isn't currently working with the latest revision of Simtools and I am living without it but I wouldn't put up with losing heave.
  10. FrankXX
    FrankXX New Member
    6Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SCN6, Arduino, JRK
    I was curious about how the two motors in the back worked,I couldn't see them.
