My 2dof simulator project
Discussion in 'DIY Motion Simulator Projects' started by Juanjo1986, Jan 24, 2017.
  1. Juanjo1986
    Juanjo1986 Member
    Comerciante.. Copiloto Rally...
    Argentina
    489Coins
    I am with a problem I do not take the games GameManager I do not know if it will be plugin problem, I drag them to SimTools_PluginUpdater, correct installation. But I do not start the move
    I test motion from the utilities and from the GamaEngine from OutputTestin and everything works wonders
  2. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    I have several attempts to register and I have not been able to. I was using Wi-Fi and there was no luck, I brought the cpu to the desk and connected it directly to the network and I was not lucky. I have disabled the Firewall and could not register myself. I do not know what will be happening
    150,025Coins
    +10,993 / 54 / -2
    Just checking, you can't have SimTools Game Engine and Game Manager running while registering, they have to be closed and the Registration program can then be started.
    Also are you using SimTools 2.1, as that fixed a Registration bug?
  4. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    SimTools Game Engine and Game Manager I have them closed and also I have no connection for registration. And I'm using version 2.1
    150,025Coins
    +10,993 / 54 / -2
    I know you said you turned it off but what firewall are you using?
  6. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Windows 7 Original Firewall
  7. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Firewall disabled.
    Avast Antivirus disabled.
    150,025Coins
    +10,993 / 54 / -2
  9. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    As you said noorbeast just could solve it by updating framework 4.0 to 4.6.2. That way if I could register ... thank you very much, surely I did not find much result of this subject since not all happens to them this
  10. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    I am not having connection between Gane Engine, Game Manager and rFactor like for example. I'm using Windows 7 Ultimate
  11. Pit
    30,463Coins
    Try 40% instead of 4%...and please upload screenshots of the tuning center and game manager.
  12. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Hello friends return after a long time.
    I have the following try the source HP 12v 46am 575w. at some maximum consumption very fast it makes me mode protection ... I have to restart and returns to your normal.
    check your voltage and is well, in use not low 12,30v.
    another issue, my controller is armed with bridges H IBT-2. I want to change engines for 24V and put two sources in series ..
    I use my IBT-2 or do I have to change them?
  13. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    come the bass shaker for the cockpit
  14. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    I have the following problem that I can not register to get an extension for the GameVibe
    https://simtools.us/member-login/
    I charge my mail and password and it tells me the following
    There are no users registered with this email address.
    150,025Coins
    +10,993 / 54 / -2
    It expects you to use the email you used to register with xsimulator.net.
    Perhaps use the contact page to request assistance, as nobody here can help: https://simtools.us/contact-us/
  16. Pastrana
    Pastrana Member
    Argentina
    165Coins
    It has arrived, congratulations.
  17. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Well I bring you some advances that a while ago ..
    Hydraulic brake pedal, use a Peugeot 504 embrage pump
    At that time I armed it with a Valve spring from Scort, but it was not hard enough, then I got the longspinners or skateboards and with that I achieved an interesting hardness.
    IMG_20181026_103017722.jpg IMG_20181026_103020684.jpg IMG_20181026_115236398_HDR.jpg IMG_20181026_115246815_HDR.jpg IMG_20181026_180005179.jpg IMG_20181026_183609938.jpg IMG_20181029_183423765.jpg IMG_20181102_151931624.jpg IMG_20181102_151937294.jpg IMG_20181102_151950286.jpg IMG_20181114_072922912.jpg
  18. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
  19. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    hello I wanted to see if there is any tutorial of the isolate of the source model HP DPS-700GB A and make a connection in series to opt 24V
