Showroom Contruccion simulador 2DOF
Discussion in 'DIY Motion Simulator Projects' started by Titobial, Mar 7, 2017.
  1. Titobial
    Titobial Member
    Zaragoza
    107Coins
    Hola. Me presento: Soy Héctor, estoy Fabricando mi simulador con Arduino, moster, potenciometros, motores ..
    Adjunto algunas fotos de mi avance upload_2017-3-7_11-56-10.png y desarrollo:
  2. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    You should write in English, it's more easy to give you support.
  3. mirkobastianini
    informatic
    italy
    1,300Coins
    It's an International Forum, so you MUST write in English. If you want, you can also attach the original traduction.
  4. Diego Efrain Quintero
    Diego Efrain Quintero New Member
    Santiago de Querétaro, México
    209Coins
    I'm sorry, i'm new and i was asking since i'm new in arduino and simulators is he can provide me a link with a tutorial or some code to get the data from sim tools to an arduino, i have been reading but didn't know how to do it until now, i don't understand very well the documentation about the interfaces and don't know how to read the serial data so i can control a motor
  5. mirkobastianini
    informatic
    italy
    1,300Coins
    Don't worry.
    If you want, introduce yourself here:
    https://www.xsimulator.net/communit...mber-introduce-here.1737/page-179#post-128225
    and as @noorbeast said:
    "You have come to the right place, there is a really active community here who freely give of their time and expertise.
    Spend some time planning and check out existing member builds, that may help you refine your own projects: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    You will find plenty to get you started in the FAQs, from design software, dimension of sims, to PSUs, pots, motors, JRKs, Arduinos and Motor Monsters and more: http://www.xsimulator.net/community/faq/
    We have a glossary for all those acronyms we tend to use, which will help you decipher some descriptions: http://www.xsimulator.net/community/faq/glossary-of-acronyms-and-names.66/
    Good luck with your project.
  6. Diego Efrain Quintero
    209Coins
    Hey thanks a lot mirkobastianini you have been a great help i'm going to check out the links to get more ideas about the arduino and simtools connection thanks a lot
  7. Diego Efrain Quintero
    209Coins
    Thanks a lot mikrobastianini i'll introduce me and check the links you provide me thanks for your help when i get my first project plan, i hope to present it to the community
  8. mirkobastianini
    informatic
    italy
    1,300Coins
  9. Titobial
    Titobial Member
    Zaragoza
    107Coins
    Hi. Agree. Should I create another new thread translated into English?
    Or can I translate this? Thanks for your response and help. A greeting.
    153,703Coins
  11. Titobial
    Titobial Member
    Zaragoza
    107Coins
    [Quote = "noorbeast, mensaje: 129945, miembro de: 10786"] Puede editar los mensajes aquí en este hilo y sólo tiene que añadir la traducción Google: https://www.xsimulator.net/community/faq/edit-your-own -posts.235 / [/ QUOTE]
    ¡Hola! Muchas gracias por contestar y darme su ayuda ... He visto lo que me cuentas de la edición de mi propio hilo de traducirlo en Inglés. Pero no veo la opción "Editar". ¿Qué hago mal? Gracias de nuevo.
  12. Pit
    30,510Coins
    https://translate.google.com/
