Question SCN5 Not detected in Simtools with new USB Adapters Help
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Ahmad Said, Mar 7, 2017.
  1. Ahmad Said
    Ahmad Said New Member Gold Contributor
    Malaysia
    208Coins
    2DOF, 3DOF, SCN5
    I just bought 2 of this recently to replace another USB to serial Adapter :
    USB to Serial RS232/UART RS485/TTL DB9 Adapter Converter Module FTDI FT232BM/BL
    http://www.ebay.com/itm/331753409742?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    Connection was made from SCN5 using 9 pin serial port harness (RS232) which worked perfectly using a different USB adaptor (frex Motion-2)
    Installed the driver manually. However, I did not get any initialization when opening Simtools Game Engine
    I also tried to connect the SCN5 directly to the blue terminal (Ground A,B) ( see picture) and no luck.
    Am I missing a step somewhere?
  2. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Have you installed the correct FTDI drivers?
    Malaysia
    208Coins
    2DOF, 3DOF, SCN5
    Yes, I did so manually as recommended by the website.
    I have one adaptor working now. It is the one that is connected via rs485, previously, I forgot to re-position the jumpers on the adaptor to reflect that.
    However the one connected via rs232 still does not work.
  4. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    That may be a cable issue due to the pins. i bought 9 pin cables and they were wrong. i cant remember what they were, but the pin connections were different. in the end i just used usb
    152,397Coins
    +11,077 / 56 / -2
    Malaysia
    208Coins
    2DOF, 3DOF, SCN5
    all ID are already 0. by default.
    Malaysia
    208Coins
    2DOF, 3DOF, SCN5
    It seems at this moment, I could not make the adaptors work with rs232 port(9pin)
    I will have to cut the harness and connect them to the rs485 terminals, which works fine.
