Question What about these PSU's?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by principiamacb, Mar 10, 2017.
  1. principiamacb
    principiamacb Member
    United Kingdom
    128Coins
    152,397Coins
    +11,077 / 56 / -2
  3. principiamacb
    United Kingdom
    128Coins
    Thanks for the reply. I've found some tried and tested dps600's for £4 more each so seeing as the electrical side will be my weakness I've gone for them.
  4. Nick Moxley
    Those 700's also lack internal fans, Not suggested.
  5. grooste_lwd
    grooste_lwd Active Member
    Nederland => Friesland => Leeuwarden
    124Coins
    1 - Connect the red contacts.
    2 - connect the 2 grounds. Need to be connected @ high power!
    3 - connect the 2 12 volts. Need to be connected @ high power!
    4 - build custom cooling fans!!!!!! Connect to the 12+ and ground
    5 - done! Use power cabling for power on of!
    They give a lot of power :). Mine work good!
