Resolved First Beta test for a K8055 Interface - SimTools
Discussion in 'SimTools compatible interfaces' started by eaorobbie, Jun 19, 2014.
Is mutiply K8055 simulators a want or not needed
  1. Want
    85.7%
  2. Not Needed
    14.3%
  1. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    Non ho ben capito il problema (prtroppo il trauttore confonde molto) ma se può esserti utile intanto ti posto la configurazione dell' interfaccia, il k8055 mi sembra configurato, se in manuale ti funziona devi solo accenderre la casella "connect a simtool"
    Sperò di esserti stato utile
    I didn't understand the problem (unfortunately the translator mixed up a lot) but if it can help in the meantime can you please post the configuration of the interface, the k8055 seems configured, if you manual it works you just have to turn on the "connect to simtool" hoped to essert helpful
  2. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    522Coins
    Hi billo2404,
    The Problem I had was that when I connect to simtool. my motors starts to turn slowly in one direction and I have no control of them and its started to jitter. As soon as I uncheck the connect to simtool box, i managed to stop it and drag the slider bar to move them back in neutral position. I find that my K8055 interface isn't communicate with simtool game engine.
    When it is not connected to simtool, I can manually move my motors to max & min by sliding the bar. And Also I tried output testing them, It isn't responding.
    I tried changing the port to different value to 4123 or 9600, its started to jitter when I check connect to simtool box.
    My FS9 game is running and I can see the values are changing in tuning center. That tells me it extracting the DOF values from the game. I don't know Where has gone wrong?
    Cyberxu
  3. auryza
    auryza Active Member
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Hi cyberxu ,
    Did you have tried change "packet rate" values ? Try change it from 10 ms to 20 ms or more . Actually it have to work without problem with 20 ms .
  4. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    hai controllato i trimmer della k8055?
    devono essere tutti e due al massimo
    have you checked the trimmers of k8055? must be both the most
  5. eaorobbie
    20,501Coins
    Before even testing in Simtools you need to be able to comfortably run them in App as able to move them without them freaking out.
    Set the timing right first then make sure the pots are right then set a Fast and Slow speed and enable motor and test with Manual Slider, while testing you can adjust the fast and slow speeds to make it better plus also if the motor seem to lag as in not move will with the slider increase the response slider.
    Once motors are moving well you can then connect to simtools and test their and enjoy a game or two.
    Once you have all the setting right , press save and next time it reloads all your settings should be good to go.
    Hope that helps.
  6. scott89
    scott89 scottlolo89
    316Coins
    2DOF, AC motor, Motion platform
    the setup exe 12.0.21005.1 v1 version of does not function
    I N do not arrive has L to install which is the procedure
  7. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    Use the standalone version for the moment.
  8. MagicEdge
    MagicEdge Active Member Gold Contributor
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    In the beginning the Velleman VM110N was a candidate for my motion control. At the time there was little to no interest in SimTools integration. Now we have it! Can 2 of the VM110N be used at the same time? Any 3 DOF and more will require more than one. What is the latest work being done?
  9. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Oh, Thank you Robert.
  10. Keroppi
    Keroppi New Member
    USA
    - 129Coins
    2DOF, Motion platform, 4DOF
    I am excited to learn that there is now some K8055 support! Since most of the work appears done, is it possible/planned to add pulse mode digital output support for pneumatics, instead of just DAC pin (like shown in pic)? I know it is not a common need, but for some users it would be great! I have 2 sims that I have K8055 for, and still stuck on the old software!
  11. Keroppi
    Keroppi New Member
    USA
    - 129Coins
    Any update on this?
  12. Mxcobra
    Mxcobra Member
    229Coins
    Bump on this , I would be running a similar setup with a stock valve body from an old rock n ride, and controlling that with a new k8055
  13. Hexpgots
    Hexpgots New Member
    208Coins
    SimAxe
    Bonjour,
    Je configure un simulateur DIY 2DOF pour une association pour le week-end qui arrive afin de faire essayer la conduite à tous pendant une journée du sport auto organisé dans mon village.
    Je suis gérant d'une petite boite d'informatique et me suis proposé pour leur configuré, hier j'y ai passer la journée, impossible !!!
    L'installation de simtools se passe bien. Sa carte étant une k8055 elle n'est pas reconnu d'office par simtools, j'ai donc pris ceci dans un premier temps :
    Ce logiciels fonctionne très bien, je peux orienté le simulateur correctement sur ces deux axes. Seul soucis, ce logiciel ne communique pas avec simtools si j'ai bien compris.
    J'ai donc pris celui ci :
    K8055 Interface V1 - 2 DOF 2014-07-07
    Qui lui à l'air de pouvoir être configurable pour simtools mais impossible de l'installé car erreur à chaque fois.
    Le PC de base est un Windows 10 64bits, je me suis dit que ce pouvais être la version, j'ai pris un PC avec Windows 7 32bits et un autre avec windows XP et c'est pareil.
    L'erreur que me renvoi le setup est :
    Impossible de télécharger l'application. Des fichiers manquent pour l'application. Pour obtenir de l'aide, contactez le fournisseur de l'application.
    Le truc c'est que la journée organisé à lieu ce week-end donc je manque cruellement de temps.
    Si quelqu'un peut me renseigné ce serait très cool.
    hexpgots
    Hello,I set up a DIY simulator to an association for the weekend happens in order to try driving at all for a day of motorsport held in my village.
    I am manager of a small computer box and set myself to set them yesterday I have spend the day, not !!!Installing simtools goes well. The card is a K8055 is not automatically recognized by simtools, so I took this at first:
    This software works very well, I directed the simulator correctly on both axes. The only problem, this software does not communicate with simtools if I understand.
    So I took this one:
    That her air of being configurable to simtools but not installed because the error each time.
    The basic PC is a 64bit Windows 10, I thought that this could be the version I took a PC with Windows 7 32bit and another with windows XP and it is similar.
    The error that setup is referring me:Unable to download the application. Missing files for the application. For assistance, contact the application vendor.The thing is that the day held in place this weekend so I sorely lacking time.
    If anyone can informed me it would be very cool.
    hexpgots
    Google Traduction
  14. eaorobbie
    20,501Coins
  15. Luc1gnol0
    Luc1gnol0 New Member
    Itala, Italy
    246Coins
    the app crash when any game start...
  16. robcoll
    robcoll Member
    305Coins
    Iam Pretty much want to say..that I have fallow this threat for a while...!!
    I want to thanks eaorobbie..you have done it with sweat and Passion...!!helping others is not an easy task..but I have seen you work with other in this forum on a determined way to "get it done" and right...!!! I Was lost when I couldn't fine program that interface with k8055/VM110 and Simtools..I have started my 2dof simulator for car or truck a year ago...and my setup is k8055/sabertooth...Thanks to you I think I can Make it works...You Rocks....!!!Thanks
  17. koko17
    koko17 New Member
    England
    28Coins
    2DOF, DC motor
    Hi robcoll, did you ever get simtools to work with your k8055 board? I am having problems trying to get the k8055 interface v1 to connect with simtools. I have the same set up as you (a diy 2dof simulator with the k8055 & sabertooth). I think my problem is with the interface settings in simtools game engine, i'm not sure if i've set it up correctly. If you are up & running you could really help me out. Thanks.
  18. noorbeast
    153,691Coins
    SimTools 2.0 Input Settings - The difference from SimTools 1.3 to SimTools 2.0 in setup is that instead of axis defined like this <Axis1> it is now like this to designate grouping for a or b <Axis1a>
  19. koko17
    koko17 New Member
    England
    28Coins
    2DOF, DC motor
    Thanks for your help noorbeast, i will try that out now, hope it works.....
  20. koko17
    koko17 New Member
    England
    28Coins
    2DOF, DC motor
    Hi Noorbeast, thanks for your answer. Here is an image of the changes i have made to the interface settings, not sure if i have done it correctly. K8055 interface V1 still will not connect to Simtools 2.1. I have spent hours over the last 3 days trying to work this out. I know some sim racers have managed to get the K8055 interface V1 to connect to Simtools, i just wish i knew how they did it.........
      323.2 KB
      943
