simulador 2dof arduino inicio
Discussion in 'SimTools compatible interfaces' started by Claudemir, Nov 22, 2013.
  1. Nick Moxley
    Dude you got a warning already , and now your doing it again ? are you seriously looking for a Perma Ban.....The Power's that be CAN make that happen if you so choose.
  2. dualclick76
    dualclick76 Active Member
    italia
    11Coins
    mi dispiace non pensavo che potrebbe essere dovuto al blocco era solo un modo di sorridere
  3. Pit
    30,494Coins
    Please use google translator and please use smilies with cautious (with sense...).
  4. bsft
    "I'm sorry I did not think that could be due to the block was just a way to smile"
    we have hammered him and to hopefully get it to stop I spotted him coins
  5. dualclick76
    italia
    11Coins
    ok sorry again my behavior, I repeat did not want to be a way to earn more coins, but only an abbreviation of compliments.
    152,397Coins
    +11,077 / 56 / -2
    Community etiquette is not always easy, particularly with so many people from so many different backgrounds and customs.
    Please do use the like, dislike, agree, disagree, funny, winner, informative and the other options for an existing post as an abbreviation of a compliment, not an emoticon by itself in a reply.
    Generally an emoticon or image only post is only acceptable when it truly captures the moment and in those cases it is usually a custom image that someone has deliberately gone looking for to achieve that end. It is like telling a good joke, it has to be well timed and appropriate to the flow of the thread.
    • Agree Agree x 6
  7. dualclick76
    italia
    11Coins
    ok thanks again
  8. fzxj520
    fzxj520 Active Member
    1,341Coins
    Read the manual (although the translation is not well understood), read other people's problems (guess the translation of meaning), repeatedly read the post, it would be easier to understand!
    We look forward to hands-on experiments
    Then again I do not understand a question
  9. Pit
    30,494Coins
    ...and this is an outdated thread.
  10. Claudemir
    23Coins
    Good evening @RufusDufus here is the end result of a more Arduino simulator mounted with Simtools more SMC3 with Chinese H bridge!
    Although I have not had much success with Chinese plates.:(
    Chinese card does not support this type of weight motore.
    I need to use a Brazilian board, Blackmoon - DC Motor Controller
    But my Arduino code, SMC3 is not compatible with this board would be grateful if someone would write a new code to use this new card that was produced in Brazil.:sos http://www.gotronics.com.br/products/blackmoon/ @RufusDufus
  11. Claudemir
    23Coins
    @RufusDufus
    Good Morning ! @ I am reopening this post because I am intent on making a Gallardo lamborghini in real-scale fiber.
    And I'll use 4 engines in this car instead of the shock absorbers.
    My Question is as follows!
    I am using an Arduino R3 with code SMC3 with placaca Driver BTS7970 Chinese, but the SMC3 code has only 3 axes.
    Can I use two Arduinos with code SMC3 to build my simulator?
    The intention is an arduino command 2 front axles and the second arduino to move the 2 rear axles.
    If this is not possible could it include 1 more axis in the SMC3 code?
    Because the SMC3 code contains only 3 axes.
  12. Claudemir
    23Coins
  13. noorbeast
    152,397Coins
    +11,077 / 56 / -2
    You could just use 2 Arduinos, they are readily available and pretty cheap.
  14. Claudemir
    23Coins
    I use an arduino in the sim tools Game Engine interface 1 and the second arduino in interface 2 it?
    152,397Coins
    +11,077 / 56 / -2
    Yes you just configure each arduino in the interface settings, members like @SilentChill are doing it that way to use the SMC code to control 6DOF rigs.
  16. Joao Neto
    Joao Neto Mucilon
    Computer engineer
    Salvador - Brasil
    310Coins
    Ola, tudo de boa Claudemir acompanho seu exelente trabalho aqui no Brasil.
    Eu vi aqui que no primeiro projeto vc usou um motor bosh, aparentemente identico ao que eu comprei, você trocou ele porque não foi satisfatorio a velocidade?
    Estou fazendo o motion apenas a cadeira você acha que esse motor vai dar conta do recado, já que ele não a boa distribuição de peso que o seu tinha?
    Outra coisa estou começando agora mas tenho um bom conhecimento de arduino programação e software precisando de qualquer coisa é so falar.
    Hello, all good Claudemir I accompany your excellent work here in Brazil.
    I saw here that in the first project you used a bosh engine, apparently identical to what I bought, you changed it because it was not satisfactory speed?
    I'm doing the motion just the chair do you think this engine will handle the message, since he does not have the good distribution of weight that yours had?
    Another thing I'm starting now but I have a good knowledge of arduino programming and software needing anything is just talk.
