Iracing drive mountain up and down
Discussion in 'iRacing' started by martin falz, Mar 24, 2017.
  1. martin falz
    martin falz Member
    Deutschland
    228Coins
    Hello
    I hope anyone can help me. I have built a motion rig from this forum.
    It is very nice and make his job.
    but I have a problem with Iracing. In Projekt Cars when I drive the Nordschleife, than goes the seat up and down by Hillclimbing.( very cool)
    but in Iracing is it very slow?
    is the reason wrong justage? or comes from the game not so many commands?
    sry for my bad english.
    152,397Coins
    +11,077 / 56 / -2
  3. martin falz
    martin falz Member
    Deutschland
    228Coins
    Thx. I test it this evening.
  4. gollum555
    gollum555 New Member Gold Contributor
    - 140Coins
    I have the same problem, "Extra2 the value heave-1g". , When I set up extra2 to 1 or 150 nothing is changing
  5. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,287Coins
    Extra2 is an alternate for Heave - this is used for road bumps sensation.
    Pitch is needed for sensation of going up and down hills. Reduce the value in tuning center to have more effect in sim.
    Both work for me.
    Post screenshots of your iracing profile tuning center settings and axis assignments.
  6. gollum555
    - 140Coins
  7. Nick Moxley
    That is not your Tuning center. Right click on Game Engine Icon in your Task bar. Those are the numbers Roofus is asking for...along with your Axis assignments as you've posted already.
    PS are you only running Roll, Pitch and surge ?
  8. gollum555
    - 140Coins
    Roll pirch and surge are for testing how to setup it, let's say temporary solution,
    Below screen
  9. Nick Moxley
    Those appear to be default numbers in your tuning center. Running 1 force at a time and understanding what's what and how it works is Critical imo. Stick with Flat tracks for now, Leave the Banking/Roll/Sway issue for later. Learning the basics will go a lot further in the long run.
  10. gollum555
    - 140Coins
    Fully understand slow way of learning step by step, this I did with DIRT , and working brilliant , but with
    Iracing, I don;t know why , I cannot feel any forces , or I feel a little bit of force, really a little, just small movement nothing else, this is the problem. When driving cannot feel breaking or accelerating, some movement left or right, and when I hit the band than seat starts movening.
    Is there any parameter which I need to change in .ini file in Iracing, or I have to do smth with simtool ?
    Pcars Dirts Asseto are working really nice , but Iracing ...., hmmm,
  11. Nick Moxley
    Tuning center values bud. PS How can you have adjusted Dirt to work properly without touching the tuning center may i ask ?
  12. gollum555
    - 140Coins
    First of all, I'm moron , I have tried to adjust tuning center in Iracing but without results, now is working , now time for real adjustement all forces , thanks for tip.
    By the way, DIRT -> Prehaps I have played in tuning center in the past, and forgot about this
    Sorry for stupid questions , but finnaly Iracing working nice. ;-)
  13. Nick Moxley
    One force at a time, Realize One force by itself might feel "dull or not enough" Just bare with me, Get all the forces tuned to where you think they should be, Then Turn them ALL back on, and you'll be amazed. Trust me.
