Tutorial SCN5 Wiring Tutorial
Discussion in 'SimTools compatible interfaces' started by nclabs, Jun 19, 2014.
  1. Hmaia
    Hmaia Member
    Engineer
    Portland, OR
    139Coins
    3DOF, SCN5
    My project is 3DOF using SCN5's. I am including a schematic showing one of the the actuators and circuitry. I would appreciate if anyone would comment on the accuracy of the schematic. It is the kind of project where you do not want to make a mistake. Thank you Bob Williams, for the comment on the usb to RS485. I will order the units I need.
  2. Hmaia
    Hmaia Member
    Engineer
    Portland, OR
    139Coins
    3DOF, SCN5
    Thank you, Bob. I have ordered three units.
  3. Hmaia
    Hmaia Member
    Engineer
    Portland, OR
    139Coins
    3DOF, SCN5
    Is there need to use shielded cable to connect to SCN5?
    I am concerned about electrical noise.
    Did any of the users o f SCN5's experience problems with electrical noise, like unwanted movement?
  4. abs
    consultant
    Montreal
    765Coins
    3DOF, SCN5
    I use regular 20 awg wires . Use 20 or less . there is no noise or unwanted motion
    for data i d suggest minimum 28 but you can use also 20 awg
    for power 20 awg and lower (18 etc.)
  5. iñigo
    iñigo New Member
    Llodio, Pais Vasco, Spain
    393Coins
    Hi ...i used this scheme.without dioder and resistor
  6. Hmaia
    Hmaia Member
    Engineer
    Portland, OR
    139Coins
    3DOF, SCN5
    IMG_5686.JPG I have finished the wiring of the control box. Still to be done: mount the USB to 485RS converters to the control box. I am waiting for 2 terminal blocks; one will be used to connect terminal A, B and GND of the converters to the SCN5 data terminal, the other will be used to support the converters (will be epoxied to the terminal block) and then bolted to the control box.
  7. hamdi.kamal
    hamdi.kamal New Member
    121Coins
    thanks for great tutorial more i read n more iam learn ....still prepare for my first project thanks
  8. DaVinster
    DaVinster Active Member
    What does I.T. stand for?
    AB, Canaduh
    1,150Coins
    3DOF, SCN6, Motion platform
  9. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    875Coins
    2DOF, SCN5
    Knock on wood......7+yrs scn5-100 without incident, pushing around a steady 215lbs. Quit smoking 9 yrs ago and put on 40lbs. and as reward bought a pc and then built my rig thanks to you guys. With the price of cigs today.... I'm way ahead. Maybe it's time to start working on those 40lbs! ;-)
  10. BlazinH
    16,704Coins
  11. DaVinster
    AB, Canaduh
    1,150Coins
    Thanks BlazinH for the quick reply. I have the e-bay link and ready to press 'buy' three of these. I needed clarification that simtools wasn't written for a specific chipset with these RS485 adapters.
  12. BlazinH
    16,704Coins
    I don’t know what adapter was used when testing Simtools but since
    any program or adapter that states use of the R$-485 interface should be compatible with each other; thus why I stated, “any true USB to RS485 converter should work”. That being said, it has been reported here that some don’t work as they should.
  13. DaVinster
    AB, Canaduh
    1,150Coins
    I appreciate that. I bought two of the 'older' types as well with the same chipset as the one used in the tutorial. I'm hoping the three newer ones will work but I only bought two of the older ones as a backup. Since I can already roll one axis with simtools I'm assuming (and hoping) if I need to use the two backups, they will play nice with the existing com port.
  14. DaVinster
    AB, Canaduh
    1,150Coins
    On the plus side, these were very cheap. On the negative side, they are free shipping out of China so I don't expect to see these until the New Year. It's possible I could get them just before the Holidays but I'm not betting on it :(
  15. DaVinster
    AB, Canaduh
    1,150Coins
    I got these just before Christmas holidays but I didn't have a chance to play with them until a couple of days ago. I'm pleased to report that both of these adapters worked for me under Windows 7 32 bit. The units with the CH340T chipsets work great and do come with 64 bit drivers. I'm unsure regarding the cheaper ones.
    Also of note, this is the first CH340T that I've seen on this site verified as working. They show up on your PC as "USB 2.0 to Serial" in you comports. I'm unsure if there's any advantage to using a USB 2.0 adapter versus a USB 1.1 unit? I also liked the more expensive CH340T as it comes enclosed in a case with a mini USB to USB cable included.
    Another note, both of these were literally 'plug and play' as windows found drivers for them from windows update. I did however download and install the drivers the ebay ad pointed to for the CH340T USB 2.0 RS485 adapters and updated the drivers windows had installed.
    Both of these type units were ridiculously cheap with free shipping and surprising didn't take that long out of China. (see my previous posts for links to the ebay auctions I used) I hope this helps someone looking for inexpensive rs485 adapters that have been verified as working with simtools. They work great with my Dyadic SCN6's too.
    Cheers,
    DaV
  16. DaVinster
    AB, Canaduh
    1,150Coins
    For convenience, here are the two RS485 converters I purchased off e-bay that I got working with Simtools. These were cheap out of China, arrived fairly quickly and I had no issues with any of the 5 modules I purchased. Your mileage may vary :rolleyes:
    $6.27 USD w/free shipping (USB 2.0 & CH340T Chipset - cable included)
    http://www.ebay.ca/itm/USB-to-RS485...sh=item2c8e87d5a0:g:r1AAAOSwPgxVQd6s#shpCntId
    $2.71 USD w/free shipping
    http://www.ebay.com/itm/181931877530?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    Cheers,
    DaV
  17. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Thanks!!! Very much appresiated.
  18. Renoboss
    Renoboss Member SimAxe Beta Tester Gold Contributor
    Work, Motion Simulator and High Tech Fishing
    Netherlands (Frisian)
    297Coins
    2DOF, SCN5
    This is correct !!!
    The S03 JPN ILK were used in the original FREX SimConMotion !!
    On my Frex the Pin8 ILK is a "grey" wire. (so connects to 0V)
    (On the original Frex using S03 JPN ILK's the supplied wiringcabels have ILK already connected to 0V)
  19. abs
    consultant
    Montreal
    765Coins
    3DOF, SCN5
    idealy power : 20 gauge (awg) , 18 should be fine too
    data : 24 to 28 awg. a bit thicker is fine too
    in a nutshell there is not such a thing as too big but too thin might be a problem
  20. michael haertsch
    michael haertsch Member Gold Contributor
    - 206Coins
    What i m musst Writing in the Interface Setting from Simtools.
    My RS485/USB Converter not works with;
    Inerface Type; SNC
    Comport; Com..(USB connect from my usb to RS485 converter with SNC5)
    Output Rate; 10ms
    Assinged; Axis 1a(Interface 1) Axis 2a(Interface 2)
    Speed; 10000
    Acceleration; 400
    X-Sim works fine but this Simtools ever not works.
