New low cost project: "scissors jack actuator" (12V) UPDATE SUCCEED 04-23-2017
Discussion in 'Motor actuators and drivers' started by Pit, Mar 19, 2017.
  1. Pit
    30,510Coins
    Hey guys,
    The upcoming days I will try to add a 12V or 24V motor (both running on 12V) to a scissors jack:
    A flexible shaft coupling 12/14mm, 8NM
    a 12V winch w/o planetary gear:
    all the rest as usual, Arduino, VNH2SP30 or VNH5019 etc.
    • Like Like x 5
    • Optimistic Optimistic x 1
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    • Funny Funny x 2
  3. speedy
    Alexandria , Egypt
    7,948Coins
  4. speedy
    Alexandria , Egypt
    7,948Coins
  5. speedy
    Alexandria , Egypt
    7,948Coins
  6. Pit
    30,510Coins
    First approach, still very early prototype and my second attempt. First I tried to add the coupler at the other end of the threaded rod, but due to the very bad welding of the Chinese scissors I had to tinker a new design. Tomorrow I will try to add the potentiometer. PS: I'm using a winch motor.
    • Creative Creative x 2
  7. speedy
    Alexandria , Egypt
    7,948Coins
    IMHO this is the best place ... to measure the angle :cheers .
  8. Pit
    30,510Coins
    Thanks, eventually I will use a slide potentiometer.
  9. RandomCoder
    Control Engineer
    1,674Coins
    Or a string potentiometer would fit in nice there.... http://www.unimeasure.com/std-a.htm
    I've just done a quick search for "String potentiometer" across the forum and didn't find anyone advising against this type of measurement? If the spring tension is sufficient then it should give good results. But I agree if you can get a linear slide pot in there it would probably be better.
  10. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @Pit could you replace the threaded bar in the jack with the ball screw type thread found in the diy linear actuator would be faster and smoother ?
  11. Pit
    30,510Coins
    It's only for testing purpose, if I would build one for professional use I would use high industrial standard parts. But thanks for your suggestion anyway :)
  12. Pit
    30,510Coins
    That's completely new to me. Slide potis are cheap and effective, unfortunately my 10 cm slide pot is not covering the full range. But almost...video tomorrow or after tomorrow.
  13. speedy
    Alexandria , Egypt
    7,948Coins
    I guess you can use those 10 cm with the linear up/down motion ... not with the lead screw .
  14. speedy
    Alexandria , Egypt
    7,948Coins
  15. Pit
    30,510Coins
    it works, but.........not really well. The scissors jack is just bs, weak, twisted, worthless junk. Though as far you can determine the concept of my (poor) design does it's job, pretty fast and very powerful.
  16. SeatTime
    Nice proof of concept, but just like EBay actuators, they just fall apart. Look forward to see were you go with this - maybe a DIY properly made ballscrew version :think.
  17. Pit
    30,510Coins
    Agree, I'm tinkering with it :), just looking for the parts where to get.
  18. Pit
    30,510Coins
  19. speedy
    Alexandria , Egypt
    7,948Coins
  20. Pit
    30,510Coins
    OK, I'm back lol. Now with a new low cost project, the last one (scissor jack for cars) was a non-starter.
    As usual stay tuned. ASAP I get the bike jack I'll start tinkering.
