Question Iracing edit path is not valit for patching???
Discussion in 'SimTools DIY Version' started by martin falz, Apr 1, 2017.
  1. martin falz
    martin falz Member
    Deutschland
    228Coins
    Hello
    I have a problem with the game patching path.
    If i have the path to the iracing has then write me the program:
    The selected path is not valid for patching !!!
    What can I do about it. At Project cars everything works. But iracing not?
    It worked until yesterday everything well. This morning simtools 2.1 tried to make it. But nothing works.
    Now I have 1.3 again and it funtioniert project cars but not iracing.
    please help me
    152,397Coins
    +11,077 / 56 / -2
    Were you using the licensed version of 2.1, or is it in demo mode?
    Did you totally remove 1.3 before installing 2.1?
    What path were you using for patching iRacing?
  3. martin falz
    martin falz Member
    Deutschland
    228Coins
    I had use the license version from 2.1.
    By 1.3 I give the path were iracing is installed. C: programs (x86) iracing
  4. martin falz
    martin falz Member
    Deutschland
    228Coins
    I had reinstalled the 1.3 before I installed the 2.1.
    Or is a trick by uninstalling
    152,397Coins
    +11,077 / 56 / -2
    You have to totally remove 1.3 for a 2.1 install.
  6. martin falz
    martin falz Member
    Deutschland
    228Coins
    Yes that I have made completely deinstaliert.
    At 2.1 I have entered the whole data and axes again, but I have with 2.1 at all no movement in the sim.
    Or do I have to set something else at 2.1?
    [A<Axis1>][B<Axis2>][C<Axis3>]
  7. yobuddy
    51,128Coins
    [A<Axis1a>][B<Axis2a>][C<Axis3a>]
  8. martin falz
    martin falz Member
    Deutschland
    228Coins
    I have made all the settings as in 1.3
    I can also create the max min in the tunning center.
    Only it does not affect the engines.
    When I test the seat with smc3 it works.
    Now again everything deinstaliert and re-instaliert but no change!
    Times the setups tacked.
  9. yobuddy
    51,128Coins
    @martin falz,
    There are 2 sets of axis assignments now, you need to tell SimTools which one to use.
    Here I'm telling it to use set 'a'.
  10. martin falz
    martin falz Member
    Deutschland
    228Coins
