Pas de mouvement du T1000
Discussion in 'Commercial Simulators and Peripherie' started by JOHNALPHA, Apr 9, 2017.
  1. JOHNALPHA
    JOHNALPHA New Member
    Reunion Island
    147Coins
    Bonjour à tous , je rencontre un problème sur dirt avec les vérins du T1000 , DIRT est bien reconnu et patché il apparaît dans le GE et le GM , j'ai fais un tuning center pour rectifier les valeurs mais le simu ne bouge toujours pas quand je lance le jeu .
    Si vous avez une petite idée merci pour le partage .
    Bonne soirée
  2. Pit
    30,510Coins
    Hi, your thread has been moved to the commercial section. Only English is allowed or use Google translator for further support.
  3. JOHNALPHA
    Reunion Island
    147Coins
    Hi every body, and sorry for my bad english !!
    I have a matter with a T 1000 2 Motions , i had patched the game in Game Manager and do a test in Tuning Center , for the max / min..
    DIRT is recognised in GE and GM
    The value are in movement when i play the game but the 2 motion don't do anythink ; nothink and nothink
    i think taht is the plugin but if you have an idea please thanks for the share.
    Have a good day and enloy it.
    153,848Coins
    +11,152 / 57 / -2
    Do you have a 32 or 64bit system, as the patch path for Codemaster games is different for each?
    The patch path for 32bit is the game install folder.
    The patch path for 64bit is C:\Users\Your_Account\Documents\My Games\DiRT3 or DiRT Rally, depending on the Codemaster game.
  5. JOHNALPHA
    Reunion Island
    147Coins
    Hi I have a 64 bit system and i put the plugin like you said "C:\Users\Your_Account\Documents\My Games\DiRT3 or DiRT Rally"
    despite that dirt is under steam i put it like you said.
  6. prosimu
    prosimu Member Gold Contributor
    - 940Coins
  7. JOHNALPHA
    Reunion Island
    147Coins
    Many thanks Patrick for every answers
    Since one week you were here to solve my questions about T 1000
    I try this night ;)
    Now it's time to enjoy it !!
  8. JOHNALPHA
    Reunion Island
    147Coins
    Ooooooh Yeahhhhh
    It' s great waouhhh
    Thanks for the share
