vthinsel
F1 2016 UDP Plugin - Manual plugin start 1.0
F1 2016 UDP plugin
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,044Coins
    Arduino, 4DOF
    vthinsel submitted a new resource:
    F1 2016 UDP Plugin - F1 2016 UDP plugin
  2. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    top work. shame The ps4 isn't OSW compatible. i doubt my ps4 will ever get used again unless i can get the wheel to work
  3. vthinsel
    FRANCE
    6,044Coins
    Arduino, 4DOF
    You never know.... no one would have thought UDP telemetry would come one day to consoles. But I agree, this one will be tough ! :oops:
  4. Bordiin
    Bordiin Active Member
    Brazil
    159Coins
    the plugin work on XBOX one too?
  5. vthinsel
    FRANCE
    6,044Coins
    Arduino, 4DOF
    As long as you have the UDP settings in the game menu configured correctly, it should work. UDP data should be the same across all codemasters game.
  6. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    I'm having the following problem with this plugin on PS4.
    It works normally, but when stepping on the brake (movement of surge) the platform tilts to one side instead of leaning forward only.
    Anyone with this problem?
    Need some correction in the plugin?
    I await an answer.
    Thank you.
    152,541Coins
    +11,085 / 56 / -2
    Are you sure your Dir settings are correct @Leandro Kemp?
    Please post picture of all of your settings.
  8. Leandro Kemp
    Brasil
    - 10Coins
  9. SeatTime
    if this is a standard 2DOF seat mover then all your selections for actuator directions are wrong.
  10. Leandro Kemp
    Brasil
    - 10Coins
    That´s because my right engine is in an inverted position.
    Maybe the surge is reversed.
    152,541Coins
    +11,085 / 56 / -2
    It pays to correct the motor direction and ensure your rig moves as SimTools expects: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    In addition to the issue with Dir settings the totals for your Axis Allocations are way too high and likely will result in clipping, see here for a guide on creating and refining a motion profile and aim for a total of 100% across all axis, you can go a little over but take it easy: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  12. Leandro Kemp
    Brasil
    - 10Coins
    All the movements are correct including the surge. Both sides lower during braking. It happens that during a braking the right side lowers more than the left.
  13. Leandro Kemp
    Brasil
    - 10Coins
    Even refined the problem happens. The fact that an engine is inferred does not mean anything, because all the parameters of axis 2 I leave inverted.
  14. Leandro Kemp
    Brasil
    - 10Coins
    To compare my PCars UDP has the same parameters and works perfectly. This problem in F1 2016 appeared with two users, so it is very likely that there is some error in the plugin.
  15. yobuddy
    51,184Coins
    Your Axis Allocations are way too high and are clipping.
    You read the axes from left to right.
    Add up the total.
    It should total somewhere between 100% to about 125%.
    You don't want the total to be under 100% at all.
    So if your driving a motor with single DOF then set it to 100%.
    If you are mixing 2 DOF's for an axis, then I set it to 120% total.
    (Because the 2 DOF outputs will not both be 100% most of the time.)
    (So the most one DOF can take from the other is 10%.)
    Remember, your physical axis can only do 100%, so all the extra gets ignored.
    Personally I would put Roll and Pitch to 10%.
    Heave to 20%.
    And Sway and Surge to 40%.
    This makes it 110% total.
  16. Leandro Kemp
    Brasil
    - 10Coins
    Okay.
    I did that.
    The problem continues.
  17. yobuddy
    51,184Coins
    Remove the Roll and the Pitch (or set them to zero) and save.
    The try the sim again.
    Does it still persist?
  18. Leandro Kemp
    Brasil
    - 10Coins
    Does it work with Xbox S 4K?
  19. vthinsel
    FRANCE
    6,044Coins
    Arduino, 4DOF
    As long as you have the UDP option in the config screen, it should. Give it a try and let me know.
  20. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    I have a UDP plugin problem on two PC's.
    One with windos 7 and one with windows 10.
    All upgraded and with Microsoft .NET 4.0 installed.
    XBox One.
    It turns out that pCars works normally, just like all other PC games.
    The F1-2016 plugin does not work.
    When running the game, the game manager window of the game manager turns blue, but game engine crashes.
    Does anyone know if it's a plugin error or am I doing something wrong?
    I await solution.
    Thank you.
