Newbie to forum begining my 1st 2dof&loss of traction
Discussion in 'New users start here - FAQ' started by trev mac, Jun 6, 2015.
  1. trev mac
    trev mac New Member
    hastings New zealand
    - 89Coins
    have ordered ardunio & MM going this route following Pits unit winch motors on their way as well I am from New Zealand I run a rally car 2wd Impreza for fun, good skid car and it is so expensive to run so want to get my kicks from sim without having to fix & pay the big repair bills quick & easy to hit reset button LOL:)
    154,544Coins
    +11,185 / 57 / -2
    Welcome @trev mac.
    @Pit's rig can certainly deliver pretty responsive kicks, so not a bad build to follow for some hard core racing action.
  3. Pit
    30,514Coins
    Nice to see you want to go the winch route, but winches are noisier than other worm gear motors due to the planetary gear. The big advantage of winches is the worth of cost, they are moving very reactively and responsively, they are very strong but slow (23 - 30 rpm outout) so you need a long lever (more than 10cm). The advantage of the long lever the winches need only a short turn to shake the seat and are less noisy. Furthermore you can reduce the noise by doing some actions explained in the FAQ.
  4. trev mac
    trev mac New Member
    - 89Coins
    yes the price was really why I wanted to go this way
    noise well turn the volume up race cars are noisy anyway plus its going in the mancave when completed I am currently reading lots on the forum pages about rigs I currently have a basic static rig that has adjustable pedals & steering platform which I would like to utilize I hope later I can pick your brain on issues that I come across I am not to clever on the electronic front I can solder ok and I can weld & build things eg: my rally car
  5. Pit
    30,514Coins
    Ergo no issues to expect :) BTW if I raise the volume of my speaker to a moderate level the noise of the rig will be "eliminated".
  6. trev mac
    trev mac New Member
    - 89Coins
    well got a surprise birthday present from x sim today more coins great thanks for that
    I have been setting up my rc model sim over the last few days got movement in the right places running LFS
    got nearly all the parts required for the big version:popcorn need to order pots am still a little unsure which ones to use hall or wound most of what I have read like either :nerd
  7. trev mac
    trev mac New Member
    - 89Coins
    well after nearly 2 years buying and building I am getting closer to finishing my rig I have added some pictures of my build so far the frame is not finished properly I have change from using moto monster drivers as they were clones and after a lot of faulty units I am using ibt2 which works ok on the bench test I am using rufus software to run my tests also not doing traction loss just yet
    20170405_193307.jpg 20170405_193318.jpg 20170405_193330.jpg 20170405_193318.jpg 20170405_193358.jpg 20170405_193418.jpg 20170405_193239.jpg 20170405_193250.jpg
  8. beatokko
    beatokko New Member
    Chile
    244Coins
    Wow, that seems an impressive amount of work and dedication! Congrats!
  9. markwong
    markwong New Member
    china
    144Coins
  10. markwong
    markwong New Member
    china
    144Coins
  11. trev mac
    trev mac New Member
    - 89Coins
    april 2017 was last post since then have changed the complete rig to wantabe & silentchillie linear actuators making a 6dof I had to much backlash with those winch motors so I converted the motors for the linear with a 2-1 ratio on the pullies motor has plenty of torque but not enough rpm hence the ratio will post later the set up am now currently trying to make the whole thing move bloody wires every where using 1 battery & led power supplies I see silentchillie has a new project looks like I jumped the gun and made these linear actuators to soon when you look at his new build never mind get this up and running and if is ok then MkII could go in there direction
