Resolved Motor reverse problem 2DOF
Discussion in 'SimTools DIY Version' started by yacinos, May 10, 2017.
  1. yacinos
    yacinos 2DOF PROJET Gold Contributor
    france
    - 135Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, 4DOF, 6DOF
    i need help with my 2DOF projet all work fine in motion but
    when i reverse motor in the setting simtools no reverse motion in motor please help me
    hardware : Arduino UNO + 2 Hbridge + MOTOR DC
    arduino code : racing_mat2DOF
    interface setting : in attachement
    axis setting :in attachement
    projet simulator picture : in attachement
    152,045Coins
    +11,062 / 56 / -2
    Do you mean checking the Dir orange on one axis for roll has no effect?
  3. yacinos
    france
    - 135Coins
    Yes , without inverse that work ( 2 motor turn in the same direction )
    when i check reversing no reverse motion ( 2 motor dont work in inverse direction but work in one direction )
    152,045Coins
    +11,062 / 56 / -2
    I think you need to check your Arduino and its settings.
  5. yacinos
    france
    - 135Coins
    you mean programme code of arduino ?
  6. yacinos
    france
    - 135Coins
    thank you for note this : when i check reversing no reverse motion ( 2 motor dont work in inverse direction but work in one direction )
    152,045Coins
    +11,062 / 56 / -2
    Yes, and hardware.
  8. yacinos
    france
    - 135Coins
    This is Arduino CODE and Attachement picture hardware in use Please Help Me :
    Arduino code for dynamic playseat 2DOF
    Created 24 May 2011 by Jim Lindblom SparkFun Electronics https://www.sparkfun.com/products/10182 "Example Code"
    Created 24 Apr 2012 by Jean David SEDRUE Version betatest26 - 24042012 http://www.gamoover.net/Forums/index.php?topic=25907
    Updated 20 May 2013 by RacingMat in english http://www.xsimulator.net/2dof-wiper-motor-playseat/ in french : http://www.gamoover.net/Forums/index.php?topic=27617
    Updated 30 April 2014 by RacingMat (bug for value below 16 corrected)
    #define BRAKEVCC 0
    #define RV 2 //beware it's depending on your hardware wiring
    #define FW 1 //beware it's depending on your hardware wiring
    #define STOP 0
    #define BRAKEGND 3
    #define pwmMax 255 // or less, if you want to lower the maximum motor's speed
    // defining the range of potentiometer's rotation
    const int potMini=300;
    const int potMaxi=700;
    #define motLeft 0
    #define motRight 1
    #define potL A0
    #define potR A1
    // DECLARATIONS
    /* VNH2SP30 pin definitions*/
    int inApin[2] = {
    7, 4}; // INA: Clockwise input
    int inBpin[2] = {
    8, 9}; // INB: Counter-clockwise input
    int pwmpin[2] = {
    5, 6}; // PWM input
    int cspin[2] = {
    2, 3}; // CS: Current sense ANALOG input
    int enpin[2] = {
    0, 1}; // EN: Status of switches output (Analog pin)
    int statpin = 13; //not explained by Sparkfun
    /* init position value*/
    int DataValueL=512; //middle position 0-1024
    int DataValueR=512; //middle position 0-1024
    // INITIALIZATION
    void setup()
    // serial initialization
    Serial.begin(115200);
    // initialization of Arduino's pins
    pinMode(statpin, OUTPUT); //not explained by Sparkfun
    digitalWrite(statpin, LOW);
    for (int i=0; i<2; i++)
    pinMode(inApin, OUTPUT);
    pinMode(inBpin, OUTPUT);
    pinMode(pwmpin, OUTPUT);
    // Initialize braked for motor
    digitalWrite(inApin, LOW);
    digitalWrite(inBpin, LOW);
    ///////////////////////////////// Main Loop ////////////////////////////////////
    void loop()
    int sensorL,sensorR;
    readSerialData(); // DataValueR & L contain the last order received (if there is no newer received, the last is kept)
    // the previous order will still be used by the PID regulation MotorMotion Function
    sensorR = analogRead(potR); // range 0-1024
    sensorL = analogRead(potL); // range 0-1024
    motorMotion(motRight,sensorR,DataValueR);
    motorMotion(motLeft,sensorL,DataValueL);
    // Procedure: wait for complete trame
    void readSerialData()
    byte Data[3]={
    '0','0','0' };
    // keep this function short, because the loop has to be short to keep the control over the motors
    if (Serial.available()>2){
    //parse the buffer : test if the byte is the first of the order "R"
    Data[0]=Serial.read();
    if (Data[0]=='L'){
    Data[1]=Serial.read();
    Data[2]=Serial.read();
    // call the function that converts the hexa in decimal and that maps the range
    DataValueR=NormalizeData(Data);
    if (Data[0]=='R'){
    // call the function that converts the hexa in decimal and maps the range
    DataValueL=NormalizeData(Data);
    if (Serial.available()>16) Serial.flush();
    void motorMotion(int numMot,int actualPos,int targetPos)
    int Tol=33; // no order to move will be sent to the motor if the target is close to the actual position
    // this prevents short jittering moves
    //could be a parameter read from a pot on an analogic pin
    // the highest value, the calmest the simulator would be (less moves)
    int gap;
    int pwm;
    int brakingDistance=30;
    // security concern : targetPos has to be within the mechanically authorized range
    targetPos=constrain(targetPos,potMini+brakingDistance,potMaxi-brakingDistance);
    gap=abs(targetPos-actualPos);
    if (gap<= Tol) {
    motorOff(numMot); //too near to move
    else {
    // PID : calculates speed according to distance
    pwm=195;
    if (gap>50) pwm=180;
    if (gap>75) pwm=235;
    if (gap>100) pwm=255;
    pwm=map(pwm, 0, 255, 0, pwmMax); //adjust the value according to pwmMax for mechanical debugging purpose !
    // if motor is outside from the range, send motor back to the limit !
    // go forward (up)
    if ((actualPos<potMini) || (actualPos<targetPos)) motorGo(numMot, FW, pwm);
    // go reverse (down)
    if ((actualPos>potMaxi) || (actualPos>targetPos)) motorGo(numMot, RV, pwm);
    void motorOff(int motor){ //Brake Ground : free wheel actually
    digitalWrite(inApin[motor], LOW);
    digitalWrite(inBpin[motor], LOW);
    analogWrite(pwmpin[motor], 0);
    void motorOffBraked(int motor){ // "brake VCC" : short-circuit inducing electromagnetic brake
    digitalWrite(inApin[motor], HIGH);
    digitalWrite(inBpin[motor], HIGH);
    void motorGo(uint8_t motor, uint8_t direct, uint8_t pwm)
    if (motor <= 1)
    if (direct <=4)
    // Set inA[motor]
    if (direct <=1)
    else
    // Set inB[motor]
    if ((direct==0)||(direct==2))
    else
    analogWrite(pwmpin[motor], pwm);
    void motorDrive(uint8_t motor, uint8_t direct, uint8_t pwm)
    // more readable function than Jim's (for educational purpose)
    // but 50 octets heavier -> unused
    if (motor <= 1 && direct <=4)
    switch (direct) {
    case 0: //electromagnetic brake : brake VCC
    break;
    case 3: //Brake Ground (free wheel)
    break;
    case 1: // forward : beware it's depending on your hardware wiring
    break;
    case 2: // Reverse : beware it's depending on your hardware wiring
    break;
    // testPot
    void testPot(){
    Serial.print(analogRead(potR));
    Serial.print(";");
    Serial.println(analogRead(potL));
    delay(250);
    void testpulse(){
    int pw=120;
    while (true){
    motorGo(motLeft, FW, pw);
    delay(250);
    motorOff(motLeft);
    delay(250);
    motorGo(motLeft, RV, pw);
    delay(250);
    motorOff(motLeft);
    delay(500);
    motorGo(motRight, FW, pw);
    delay(250);
    motorOff(motRight);
    delay(250);
    motorGo(motRight, RV, pw);
    delay(250);
    motorOff(motRight);
    Serial.println("testpulse pwm:80");
    delay(500);
    // Function: convert Hex to Dec
    int NormalizeData(byte x[3])
    int result;
    if ((x[2]==13) || (x[2]=='R') || (x[2]=='L')) //only a LSB and Carrier Return or 'L' or 'R' in case of value below 16 (ie one CHAR and not 2)
    x[2]=x[1]; //move MSB to LSB
    x[1]='0'; //clear MSB
    for (int i=1; i<3; i++)
    if (x>47 && x<58 ){//for xA to xF
    x=x-48;
    if ( x>64 && x<71 ){//for x0 to x9
    x=x-55;
    // map the range from Xsim (0 <-> 255) to the mechanically authorized range (potMini <-> potMaxi)
    result=map((x[1]*16+x[2]),0,255,potMini,potMaxi);
    return result;
    152,045Coins
    +11,062 / 56 / -2
    I think you need to detail the hardware being used with links to it, for boards and motors.
    Also validate the setup steps with the code.
  10. yacinos
    france
    - 135Coins
    so,i work with a arduino uno generique (clone low cost),2 motor dc 6v, 2 potentiometre 10k ,and 2 h bridge L298N low cost too : ), i used them for my first test only.......what do you think about my ardwear??it's compatible??
    thank you for your help
    152,045Coins
    +11,062 / 56 / -2
    I am guessing the 6V motors and L298N are likely pretty limited in terms of their capacity.
    I am not sure if the L298N is supported, perhaps @RacingMat or others could advise.
  12. yobuddy
    51,016Coins
    @yacinos
    Remember you can always look at the virtual output window to check that the output look correct.
    May help some buddy.
  13. yacinos
    france
    - 135Coins
    in the virtual work fine but in the motor no reverse
  14. yacinos
    france
    - 135Coins
    thank you for your help !!! :)
  15. yobuddy
    51,016Coins
    you get it working @yacinos?
    I see it says this right in the top of the sketch.
    I'm guessing it stands for forward and reverse?
    Maybe has something to do with it?
  16. yacinos
    france
    - 135Coins
    hey @yobuddy ,
    i found the problem i just check my hardware wiring and i found the solution :
    My hardware was not in right wiring , now it work fine
    thank for your reponse and thank you for all @noorbeast and @yobuddy
