Question Assetto Corsa problem
Discussion in 'SimTools DIY Version' started by evolaco, May 14, 2017.
  1. evolaco
    evolaco Member
    Spain
    694Coins
    Hello, I have no answer in the motors or in simtools with Assetto Corsa, I have not tried another game, I use SMC3 and it works well, the tests with simtools also work but the game does not send signal, am I doing something wrong?
    I also have problems when the engines stop or change direction, they stop braking and then make movements to correct until they stop, I'm trying without load or moving the seat, is for that reason?
    152,391Coins
    +11,076 / 56 / -2
    It would help if you post pictures of all of your settings.
  3. evolaco
    evolaco Member
    Spain
    694Coins
    Do not let me put pictures
  4. evolaco
    evolaco Member
    Spain
    694Coins
    When you are in the car the engines focus and stay in position with force but no signal comes out of the asseto, Because I can not send pictures
    152,391Coins
    +11,076 / 56 / -2
  6. evolaco
    evolaco Member
    Spain
    694Coins
    Hello, thanks for the help, in the end it was a bad configuration of the axes, now it is already moving although I have a long way
