this motor is WORTH?
Discussion in 'Motor actuators and drivers' started by paulopsx2, May 13, 2017.
  1. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    high rpm but dont show NM !!
    153,788Coins
    +11,150 / 57 / -2
    Those are miniature DC motors and are only suitable for a model sim, not the real thing.
  3. paulopsx2
    brasil
    647Coins
    hummmm i see.. thanks.
    What is the best and strongest possible for a 2 DOF? Example 80 rpm, 50 NM ... 12 or 24v?
  4. SilentChill
    20,601Coins
  5. paulopsx2
    brasil
    647Coins
  6. SilentChill
    20,601Coins
    no its the gearbox ratio, you can also get 25:1 which has less torque
  7. paulopsx2
    brasil
    647Coins
    right.. 50:1 sounds me better for 150kg.
  8. SilentChill
    20,601Coins
    LOAD BETWEEN 50-60 N.M
  9. pakoR
    pakoR New Member
    Spain
    215Coins
  10. SilentChill
    20,601Coins
  11. paulopsx2
    brasil
    647Coins
    well... i dont know.. maybe an sabertooth or pololu?
  12. SilentChill
    20,601Coins
    Me personally would go with a Sabertooth 2x32 they are well worth the money and if you wanna go overkill get a 2x60 :)
    • Agree Agree x 3
  13. paulopsx2
    brasil
    647Coins
  14. paulopsx2
    brasil
    647Coins
    Well, continuing my saga, I discovered that these 12v or 24v engines do not last very long and can not push a lot of weight ... talking to a friend, told me that stepper is much stronger, working on 220v. is a good idea? Even if they are more expensive? And this can be used with arduino and sabertooth as well or from what I understand, sabertooth control only DC motors?
    ( my intention is 200kg + platform )
    And I am seriously thinking of going from 2 to 3 dof, the difference is great, and with the central spring, it seems to force less the engines besides giving me better result in height
    153,788Coins
    +11,150 / 57 / -2
  16. SilentChill
    20,601Coins
    I've been using 12v motors for 2 years on my 6DOF and they have lasted fine. If you want to go AC you can but you will probably need a thanos board or something like that sabertooth and arduinos are a no go. Plenty of people here using 12v/24v for 6DOF
  17. paulopsx2
    brasil
    647Coins
    well.. 2 months after some searchs and a lot money rs.. my 2 dof are done. use 2 250watts, 50nm 80 rp
    m motors !! tks
  18. masterhoo
    masterhoo New Member
    Peru
    370Coins
    Hi, @paulopsx2 could you post the motor link? or description? thank you.
  19. paulopsx2
    brasil
    647Coins
    Im on job now... i post link later
  20. My.stAr
    My.stAr Active Member
    Engineer
    1,065Coins
    DC motor
    You have a really long working day:p
