value1
Project CARS Plugin 2.0.3.3
SimTools game plugin for Project CARS
  1. noorbeast
    153,914Coins
    +11,156 / 57 / -2
  2. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    I just tried Project Cars with SimTools 2.1 and this problem is still there.
    It is a bit different now. The Session State is a number now.
    if you start a race based on time or start a career race then everything works fine, but if you start a race based on laps then it only works if you have the laps set between 9 and 13. In practice it works fine and the session state is 1, in a timed race or 9-13 lap race it works fine and the session state is 5, but if you set it to some other amount of laps then the session state is 0 and it stops outputting any data to GameDash.
    Practice, career, timed races and 9-13 lap races all work fine. Any other amount of fixed laps won't work.
    This is using the standard plugin. I haven't tried the UDP one yet so I don't know if the same bug is in the UDP plugin.
  3. SilentChill
    20,601Coins
    This is @value1 doamin :D He'll love me for tagging him lol
  4. Avenga76
    Network Engineer
    3,261Coins
    Haha, thanks in advance @value1
  5. El_Batallitas
    El_Batallitas New Member Gold Contributor
    Spain
    37Coins
    I've found a workaround:
    -Duplicate the .exe file and rename it to pCARS.exe, create a shortcut to desktop, create a pCARSOculus64.exe shortcut aswell, and place both on desktop.
    Open pCARSOculus64, wait 1 second and open pCARS.exe, it will display "game already running", leave it that way. Game manager should be turned ON now.
    This should also work for other games with the same problem.
    Good luck!
    153,914Coins
    +11,156 / 57 / -2
    Added to the FAQs here: https://www.xsimulator.net/community/faq/configure-the-oculus-version-of-project-cars.279/
  7. Avenga76
    Network Engineer
    3,261Coins
    A better way to do it is to just use something that you can leave open, like make a copy of CMD.exe or Notepad.exe, rename it to pCARS.exe and then just leave it running in the background. Then you can just launch the Oculus version of pCARS as normal.
    As long as that Notepad or CMD window is open then SimTools will think pCARS is running so you can just launch as normal.
    You can even write a batch file that will launch the newly renamed Notepad then launch the real game
    I have used this trick for heaps of games before official support comes out, like codemasters games and American Truck Sim
  8. Avenga76
    Network Engineer
    3,261Coins
    @value1 Any progress on fixing this bug?
  9. jonston5
    jonston5 New Member Gold Contributor
    Australia
    - 281Coins
    @value1 yes i too am having this issue. please help :)
  10. yobuddy
    51,538Coins
    @Avenga76,
    You ever test out the other plugin buddy?
  11. Avenga76
    Network Engineer
    3,261Coins
    Do you mean the UDP plug or is there another plugin?
  12. value1
    14,240Coins
    • Like Like x 5
  13. robertogecco
    robertogecco New Member Gold Contributor
    Austria
    25Coins
    2DOF, SCN6
    Hi value1,
    i like your plugins and they are working very well with pcars and pcars2. Is it possible to generally disable the movement during a replay?
    Great work.
    robertogecco
  14. Nick Moxley
    Interesting they kept the telem in replay again.
  15. value1
    14,240Coins
    Only by clicking Yes in the dialog box that pops up during startup:
  16. Crazywoj
    Crazywoj New Member
    Printer
    New York
    176Coins
    I was windering if this can be used for output to bass shakers
  17. jeanmehdi
    jeanmehdi New Member
    LONDON
    - 201Coins
    Sry too many post to read but i tried...
    Is the plugin working with cars 2 ?
  18. jeanmehdi
    LONDON
    - 201Coins
    Gosh just saw the answer haahahahah
    Thanks anyway ;)
  19. value1
    14,240Coins
  20. Guilherme Bastian
    Guilherme Bastian New Member
    Brazil
    151Coins
    Hi there,
    Im getting speed info while in a practice mode. However, in a quick race the information is not capture by game dash. Does anyone know how to solve this problem?
