New user - Prosimu T1000 ordered
Discussion in 'Commercial Simulators and Peripherie' started by Bacon2002, Apr 20, 2017.
  1. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    SCN6, Motion platform
    Hi to everyone,
    To introduce myself, I am new to motion simulators and Simtools (which I will be buying a licence for shortly).
    Recently I ordered a Prosimu T1000 5 motion simulator and I thought I would say hello to the community as I will no doubt have lots of questions once I have finished reading some of these threads.
    I would be very interested in peoples thoughts and any advice especially in respect of new users to Simtools and the T1000 set up etc.
    Thanks,
    David
    153,914Coins
    +11,156 / 57 / -2
    Welcome @Bacon2002.
    Use this thread for any questions you may have, as it is in the correct section for a commercial sim.
  3. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    2DOF, SCN6, Motion platform
    Hi, i have the T1000 with 2dof and it is incredible so i can only imagine what the 5 dof would feel like. In regards to simtools 2.0 i would check out the YouTube guy called RTA Motorsports as he has some good videos on the set up for simtools with the t1000.
    I wouldlove to hear your thoughts on the traction loss as i really feel i need that as when the back end steps out you can get a bit of disconnect especially in VR. Gt3/4 cars are fine as they have huge downforce via the rear wing so not much movement happens etc. I so want to get the add on but just can't afford it at the moment. :) thanks
  4. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    I will look up the videos and its good to hear the feedback which sounds positive.
    Do you have an MDF board with wheels fitted under your T1000, I was looking at a couple of posts and can't quite workout the size and thickness of MDF. Ideally I would like to be able to move the unit and also I would like to leave some board under and behind the seat as it looks like it overhangs at the back.
    I will definitely leave feedback on performance but I am not expecting delivery until the end of May. Plenty of time to work out how to explain to the wife that I just threw a load of money up the wall. Pretty sure she said something about divorce last time I mentioned wanting a motion simulator....
    David
  5. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    Hi, i do not have any MDF under mine as it's in a dedicated room but if you check out inside sim racing review of Prosimu t1000 he has what you are looking for.
    Luckily for me my wife is very understanding ha but then again i did only get the 2DOF rig :)
    Do you have a VR headset ?
  6. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    I have an Oculus Rift which is great fun, especially with racing sims (and Robot Recall).
    I had a look at the "inside sim racing review" but I'm still not entirely clear on the actual dimension of the platform, the reviewer refers to the platform being the same size as the Prosimu rug. I think that is 120cm x 95cm but I am not sure and ideally I am looking to make the platform a little bit longer than the rug (assuming of course I get a rug with the T1000?).
    Its not a problem as I probably have to build the T1000 and then workout what size platform is needed.
  7. AussieStig
    AussieStig Member
    207Coins
    Hey mate, what do you need to know about the platform? I am the reviewer, AussieStig. If you need advice you can PM me here mate. Cheers, Mark
  8. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    Hey, sorry for late reply. Great about you having a rift as I have a vive and it really is great with motion. Anyway have you got your full prosimu rig yet ?
  9. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    I will PM you Mark, I would definitely be keen to know the size of the platform. Great review on your website by the way.
    The Prosimu rig is due to arrive on 29th so a little while to go yet, I can't wait.
  10. BAER
    BAER New Member Gold Contributor
    washington
    137Coins
    Did you get the instructions? Patrick hasn't gotten back to be yet so anyone that has instructions can you please pm me. I just got the 3dof
  11. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    Yes I received and built my T1000 5DOF, I am very pleased although I would highly recommend building the unit on an 18mm MDF base platform on wheels (mine is 100cm x 170cm but the 5DOF is longer than the 3DOF so you will likely need something more like (100cm x 120cm (to 150cm depending on if you want somewhere to mount the driver units).
    If you PM me your email address I can send you the instructions.
    Its pretty straight forward to build, just take your time.
    I also ordered some plastic end caps for the red sub-frame and or the ends of the seat frame which make for a much nicer finish.
    David
  12. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    Should be in your in box
  13. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    The only thing that caused me some concern was the bolt for mounting the traction loss servo bracket to the base. I would recommended being gentle with it, essentially you need to make sure that the bolt is held in place from underneath and then slowly tighten the nut from above but don't over tighten it.
    Mine worked out fine but I could see someone easily damaging the MDF base bar by over doing it.
  14. BAER
    washington
    137Coins
    Oh yeah I over did it on that bolt, but I think I fixed it for now I'll see once I get it up and running. I'll let you know once I get it up and running. Thank you again!
  15. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    Here is the finished unit:
    I will be extending the servo driver wires so that I can mount all the electronics (apart from the main box which I will likely house within a small data box along with my transducer amp) to the front of the platform and hide all the cables.
    And here are the end caps that help finish, the big ones are 65mm x 65mm and the smaller ones are 45mm x 45mm
  16. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    Here are some pictures of the base build:
    The parts came unpainted so I sprayed them matt black:
    Ended up like this:
    Fitted some wheels using countersunk stainless steel bolts:
    Although it is not shown below in the end I bolted the two parallel MDF pieces directly to the base again using countersunk bolts and I also removed the centre bar as it really was not strong enough to maintain any sort of structural integrity:
  17. jonston5
    jonston5 New Member Gold Contributor
    Australia
    - 281Coins
    Awesome Setup :) mine is very similar. to save you the hassle of extending the cables you can buy premade extension cables from Frex. i have used 1m extensions on mine and its perfect length to reach my controller unit in the front.
  18. Shannon
    Shannon New Member Gold Contributor
    USA PA
    178Coins
    Nice setup! I just finished my build for the t1000. I also built a rolling platform which has been a great help.
  19. FlyinJake
    FlyinJake New Member
    Denmark
    239Coins
    I am considering the T1000 but i want to use it for Playstation 4 with GT Sport, Assetto Corsa and Project CARS 2. Do you know if that is possible to connect the T1000 to a pc with simtools or Gimx software and then connect the Playstation to the same pc? I have seen it possible to do this with a Direct drive wheel on YouTube.
  20. wangdaokun
    wangdaokun New Member
    2 AVENUE FRANKLIN D ROOSEVELT 21000 DIJON
    148Coins
    非常好的设计,我设计的地下有一个车轮仿真平台。非常方便的移动!
    • Dislike Dislike x 1
