Question Output a Sinusoid?
Discussion in 'SimTools Pro & Entertainment Version' started by Zed, May 14, 2017.
  1. Zed
    USA
    5,844Coins
    Hey all, is there a test mode in SimTools or a way to output a sine wave that can have a programmable amplitude and frequency to exercise motors and test throws?
  2. value1
    15,029Coins
    Good idea! I'll see, if I find the time for such a plugin!
  3. Zed
    USA
    5,844Coins
    Well that's help I didn't expect! I was just hoping there was such a beastie! Thank you very much in advance! :cheers
    And if it takes a while, that's cool too. I was just wondering if it existed. Got to admit I'd appreciate it!
    Edit - I asked what you use and what API and noticed all that is answered in the plugin support forum. Hehe. Seek and ye shall find. :thumbs
  4. value1
    15,029Coins
    @Zed
    • Drag'n'drop the zip file into the SimTools_PluginUpdater.exe as usual
    • Run GameManager in admin mode
    • Patch the "game" (select SimTools installation directory; that's also the reason, why you need to run GameManager in admin mode when patching)
    • Start GameEngine
    • Run SimTools_CurveGenerator.exe from the SimTools installation directory
    • Select the type of curve you want, select the simulated force, the IP address of GameEngine (127.0.0.1 if you run in single PC configuration) and press start.
    • Give me some feedback
    Enjoy!
    • Winner Winner x 3
    • Useful Useful x 2
  5. Zed
    USA
    5,844Coins
    Hey Value1, Thanks so much! I'll see if I can get it running this weekend!
    I don't have my sim moving yet, and it will be a couple of weeks still I think, but this will be wonderful! But I can check out the interface and functionality in the mean time.
    Dude, so cool! Thanks again and I'll let you know how it all goes!
    Quick questions - is force the amplitude? And does it exercise all channels/motors at the same time? Or do you pick a "force" like acceleration or braking, surge, TL or yaw, etc?
  6. value1
    15,029Coins
    Yes, the force is the same as in the games: acceleration or pitch or traction loss, etc.
    The amplitude is influenced via the MaxMin settings in GameEngine. For simplicity, you just define the period of the wave.
    There is no live graph of the signal or even the feedback signal. Maybe in v2 :D
  7. Zed
    USA
    5,844Coins
    That's perfect and thanks for the explanation! I think this will be very useful but know it will be for me! Will get it installed and let you know. Can't test actual movement yet, though. Bet this is very handy for standing up a new platform!
  8. Zed
    USA
    5,844Coins
    Hey @value1 - Curve Generator all installed! I'm in the middle of a print and don't want to risk disturbing anything by turning it all on, but so far, so good!
    Thank you again for this. Timing is pretty close to perfect. I'm just about to the point where I can start connecting, powering motors up, and calibrating and I bet this utility will be perfect!
    Will let you know how it goes!
    Cheers!
  9. value1
    15,029Coins
    Replace the SimTools_CurveGenerator.exe in the Simtools directory.
    Very much work-in-progress. I will try to add the JRK feedback as well and fix the startup of the graph.
  10. Hoddem
    Hoddem Well-Known Member
    Engineer
    Minnesota, USA
    3,343Coins
    Found this and started playing around with it, when I run the generator my motion only runs from center to max and back to center. When I do output testing from the game engine I have full control over the whole range of my actuator.
    Just wondering if I am missing something.
    Great tool, Thanks
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    I get same as @Hoddem, only half of the axis. I agree even with the bug its an awsome tool.
  12. value1
    15,029Coins
    This version covers a range -1 to +1
    Install the plugin as described above.
    Replace the SimTools_CurveGenerator.exe in the Simtools directory with the attached exe.
    PS: I connected a JRK and read the feedback from it. But after a while I fried it. Not sure if this is due to my coding or nothing related to the program. But don't expect a JRK-feedback-reading version shortly.
    • Winner Winner x 3
  13. bruce stephen
    general contractor
    michigan
    9,115Coins
    Brilliant work @value1, fast like greased lightning too.
    It uses the entire axis now. what you see in the video is 100% axis setting in Engine axis assignments. still need grease and ballscrew end bearing. This is single pc I will test udp later today.
    EDIT: Has this been added to the plug-ins d-load section?
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
    Ok actually @value1 it works on sine wave only. the other 4 forces are half axis. still bada$$. ty
  15. Gadget999
    12,035Coins
    if you use the SMC3 board to control your motors there is a sine output in that program also
  16. insanegr
    insanegr !N$@n€
    Athens
    16,723Coins
    with this plugin you can move all your motors and see how the sim moves without using the sliders as in GE. you can't do this in SMC3 its only one motor a time
  17. bruce stephen
    general contractor
    michigan
    9,115Coins
    yeah the closest to this for me before was running a replay from Iracing as that also has live telemtry.
  18. bruce stephen
    general contractor
    michigan
    9,115Coins
    I have 6 instances of smc3 (sketch) running at once in my current setup.
    the new actuator uses kangaroo and encoder instead of smc3 and potentiometer to control position/movement. smc3 wont work with the kangaroo as far as im aware.
  19. bruce stephen
    general contractor
    michigan
    9,115Coins
  20. RacingMat
    21,050Coins
    that looks excellent for my simulator testing! Thanks
    IMO you shoud post it in the utilities ressources :)
    https://www.xsimulator.net/community/marketplace/categories/utilities.27/
    with your explanation in #4 message
    yours
    Mat
