Mr Burn's simulator
Discussion in 'DIY Motion Simulator Projects' started by Mr Burns, Oct 17, 2008.
  1. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    @Mr Burns. - Please download my updated profile which corrects the inverted axis issue. Also, you do seem to have more rigorous movement from the same profile (assuming that you are using the profile that I uploaded.) It looks like the same approximate movements but more extreme as if the speed and accel were different. I know that you say you have set these to the recommended values for the profile, so the only thing I can think of it that the physical design differences are having an impact. From what I can see, your acceleration value needs to be reduced to produce smoother movement. I would try reducing it in increments of 50 until it feels smoother, but not so smooth that you cant sense the wheel hop in corners.
  2. Mr Burns
    Mr Burns New Member
    0Coins
    To everybody that asked, yes you can invert the effects, or set them up any way you like.
    @bvillersjr - i used the last profile you uploaded in the beta section in the profile thread. I also noticed it is reversed, but I only drove when I filmed those demo videos, and had to leave for the weekend. I'll mess with it later, maybe you'll have another profile up by then, or is it the one from the thread? Why would it be reversed in that case?
    The movements are definitely too much, I plan on adjusting everything to lower levels or I'll end up at the doctor soon.
  3. bvillersjr
    Ohio, USA
    438Coins
    I posted it backwards originally and then corrected it. It seems you got the original version. I will be posting a third more refined profile sometime this weekend.
  4. Mr Burns
    Mr Burns New Member
    0Coins
    Cool, I'll be a while until I can test it.
  5. Mr Burns
    Mr Burns New Member
    0Coins
  6. Mr Burns
    Mr Burns New Member
    0Coins
    After trying all sorts of things I put a soft mattress with a piece of wood under it and I have no more complains from the neighbors. Please ignore the wire mess, the location is not yet final and the mattress is from a furniture store garbage that's why it looks the way it does :rofl: . I provisionally mounted the pedals with some wood, it works good :D .
  7. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    you could add a leg on each corner of the wooden plate. If the length of each leg just would be e.g 1,5cm shorter than the mattress, you'd hav some addiitional safety while stepping in and out to your simulator.
    As well it seems the acutator arms are placed too much vertical still, I think.
    Regards
    Christian
  8. Mr Burns
    Mr Burns New Member
    0Coins
    I have some space to decrease the vertical angle by moving the chair and steering wheel forward, i have seen people use around 80 degrees or so, what would be a good angle (besides 45 deg)?
  9. XRiccardo
    XRiccardo New Member
    1Coins
    quote!
    and sorry but I do not understand well where you had to assemble the two special bolts SpecialViti.tiff
    can you post a photo?
    Thanks!
  10. XRiccardo
    1Coins
    ok .... I know only one thing?
    you could tell me the characteristics of the pivot? How many kg?
    Thanks!
  11. egoexpress
    422Coins
    @Xriccardo
    please upload pics as jpg
    If the filesize is too big (>250kb), then compress or resize the pic. Or both.
    Regards
    Christian
  12. XRiccardo
    1Coins
    ok Thanks!
    pivot:
    perno.tiff
    for how many kg?
    I wanted to have confirmation of resistance of the pivot.
    I weight 80 kg, the seat weighs 20 kg. I have to find a pivot for 100 kg?
    a technician explained to me that I have to increase by 1 / 10 in case of a cutting motion.
    so I have to find a pivot for 100Kg + 10 kg = 110 kg.
    is right?
    Thanks!!!!
  13. egoexpress
    422Coins
    .JPG not .tiff ! :roll:
  14. XRiccardo
    1Coins
  15. bvillersjr
    Ohio, USA
    438Coins
  16. Mr Burns
    Mr Burns New Member
    0Coins
    bvillersjr is right, look on that page. Also, I'm not sure which 2 bolts you mean, but it seems you solved the problem. Look in the wikipedia as well http://www.x-simulator.de/wiki/Main_Page . Sorry for the late response, I have been so busy, all I do is sleep and work. :eek:
  17. patatrac
    patatrac New Member
    My simulator and my family.
    318Coins
    Hi all,
    In order to connect the actuator to the seat and other, should i use:
    this element 1
    or this element 2
    Patrick
  18. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    370Coins
    Hi Patrick,
    you definitely should use element 2 / joint heads !
    The actuators must be able to move in all directions. You have to take these parts for the side stabilizers as well (to avoid distortion of the seat unit).
    Bye,
    Chris
  19. Mr Burns
    Mr Burns New Member
    0Coins
    Yes, the 2nd one or similar (with a movable inside) - the inside needs to be able to move so it can bend on the rod that you connect the actuator to.
  20. egoexpress
    422Coins
    Dont forget to order a rod end with matching fine thread pitch!
