News More DIY Linear Actuator design ideas
Discussion in 'Motor actuators and drivers' started by Bruceaust, May 21, 2017.
  1. Bruceaust
    Bruceaust Member
    CNC Routing
    Launceston, Tasmania, Australia
    63Coins
    I have been away from the sim environment for while, but i am back! with a new project.
    I have been thinking for a while now about building some diy linear actuators using G180-12 dc motors from "Motion Dynamics" , JRKs A linear Bearing, 800mm of linear rail, and notch belt drive.
    The hope is to get about 750mm of usable travel. My new sim design will be driven by 2 of these actuators, giving me about +-150mm for pitch and +_ 150mm for roll.
    I also have a few novel ideas on my new sim design which I will share when I make some progress on the CAD drawings.
    153,691Coins
  3. Bruceaust
    Bruceaust Member
    CNC Routing
    63Coins
    Must catch up some day noorbeast,
    VR stuff sounds interesting,
    Here is what I have in mind for the linear Actuator.
    Not strictly a linear actuator in the normal sense, as the out put is on the linear bearing.
    It is the simplest an most minimalist way I can think of achieving 700 to 800 mm of travel.
    The big test will be to see if the motor has enough torque. Long stroke Actuator.png
    153,691Coins
