Finding the best 2DOF structure for no limits rollercoaster
Discussion in 'DIY Motion Simulator Projects' started by kahrobaa, May 8, 2017.
  1. kahrobaa
    kahrobaa New Member
    sanaandaj
    306Coins
    Here is my 2DOF and i want to adjust setting and structure for the best performance in no limits rollercoaster. Some elements with steep slope may wont be simulated well in this design.
    photo_2017-05-08_15-32-11.jpg photo_2017-05-08_15-31-51.jpg photo_2017-05-08_15-31-37.jpg
    153,812Coins
    +11,150 / 57 / -2
    So is your plan to use the motors and electronics but build a new frame, or something else?
  3. Fluke
    Fluke Member
    Stafford, United Kingdom
    812Coins
    Looks like a nice build. :thumbs Did you do a build log? what motor and gear box's do you have fitted? Have you considered adding a third motor to the front for 3 dof?
  4. Diego Amaral
    Diego Amaral Member
    Rio de Janeiro
    98Coins
    good job!
  5. kahrobaa
    kahrobaa New Member
    sanaandaj
    306Coins
    exactly, I am looking for the most proper structure for a real experience of rollercoaster and the best performance for mechanical parts.
  6. kahrobaa
    kahrobaa New Member
    sanaandaj
    306Coins
    no building log yet, as i am just modifying the structure every week ;) , the next plan is the 3DOF model as you mentioned.
  7. MarkusB
    4,215Coins
    I just realize that you still did not get an answer to your question in the initial post.
    What I would recommend (and what I already did by myself) is:
    • Add fans for simulating wind
    • Integrate a g-seat, at least for surge. In this way you have the pitch angle and the surge force separated, which in my opinion is essential for roller coasters and planes.
    • Use VR (if this lies within your budget). I am using an Oculus Rift, and for me it is great
    At the moment I have a 2DOF full frame rig with all these add-ons. I am close to starting a new rig, but it will again become the same type of simulator. I will just improve many details (use stronger motors, use stronger fans, make it much more compact, re-design the g-seat). Looking at your current structure, my first try would be to keep it and make the listed additions.
    Of course these are only my personal experiences, and you will probably get many others and different ones.
    Best regards,
    Markus
  8. kahrobaa
    kahrobaa New Member
    sanaandaj
    306Coins
    Thanks Markus,
    I have a plan for fans, sound consideration and some light effects in near future, The main goal of this topic is finding the most compatible structure that has appropriate influence on user and acceptable life-time for mechanical parts. I would be grateful if you share your simulator.
    With regards,
    KAHROBA
  9. kahrobaa
    kahrobaa New Member
    sanaandaj
    306Coins
    The new topic that i did not find a suitable place to introduce, is about a multi VR headset use! Is it possible to use 3 or 6 VR simultaneous?
    153,812Coins
    +11,150 / 57 / -2
    Not on a single computer, but you can do VR multiplayer, if that is what you mean.
  11. kahrobaa
    kahrobaa New Member
    sanaandaj
    306Coins
    Thanks noorbeast,
    I want to make a dual seat for a rollercoaster, So by this VR multiplayer, each person can have a different view of the game?
    153,812Coins
    +11,150 / 57 / -2
    People have tried 2 VR HMDs on one computer, but realistically VR needs all the resources it can get so the better way to go is to have a multiplayer ride where the motion is shared but each person has their own VR seat position.
  13. kahrobaa
    kahrobaa New Member
    sanaandaj
    306Coins
    So multiplayer VR in this type is a same view with 2 VR headsets that is generated by movement of one headset ?!
  14. kahrobaa
    kahrobaa New Member
    sanaandaj
    306Coins
      59.9 KB
      627
      59.9 KB
      627
  15. kahrobaa
    kahrobaa New Member
    sanaandaj
    306Coins
    This is my initial design for a dual seat roller-coaster that provides more movement!
  16. noorbeast
    153,812Coins
    +11,150 / 57 / -2
    A game has to be designed for multiplayer, so there are two positions side by side in the game for each of the particpants.
  17. masterhoo
    masterhoo New Member
    Peru
    370Coins
    there is this option to use GearVr with Samsung Galaxy S6+, connect it wirelessly with the pc game, it could be for two or more players.
  18. noorbeast
    153,812Coins
    +11,150 / 57 / -2
    Be careful with this with VR newbies as the GearVR only runs at 60fps at best and network data transfer will induce lag.
  19. masterhoo
    Peru
    370Coins
    definitely.
  20. kahrobaa
    kahrobaa New Member
    sanaandaj
    306Coins
    thank you, do you have any suggestions? how can we share a multi view?
