Selling my 3 DOF rig
Discussion in 'Marketspace - Marktplatz' started by aceinthesky, May 25, 2017.
Thread Status:
Not open for further replies.
  1. aceinthesky
    aceinthesky Member Gold Contributor
    Pearland, TX
    387Coins
    Hello again to everyone, after parting out my peripherals its time to sell my motion rig. First off I have to say that the reason I'm selling is because of my busy schedule. The rig works perfect and I have made many modifications to it to make it bullet proof. Its aurdino based and works with simtools. I've used it with i racing, assetto, dcs, and many others. I was using it with a large mige, so some reinforcements had to be made. You can see build thread here (I'm aceinthesky) https://www.xsimulator.net/community/threads/low-c...r-kit-dynamic-kit.8570/page-4.
    The rig has two control boxes, one controls the yaw axis, the other both roll and pitch. The rig is ready to have a shifter mounted on the right see with a stout aluminum mount that does not move. I also made a holder for the e-brake, which I left the brake attached too for demonstration purposes. There are different options on the website and I purchased the comercial grade version of the motors and gearing for longevity and reliability.
    I bought my rig from this website http://dofreality.com/
    Its set up to where you can mount a buttkicker, under seat, pedals, next to shifter, and under wheel. It also has two mount next to the pedal base for chassis setup, The rear buttkicker for chassis set up can be mounted on the rear seal bar.
    Im only asking $2300.00 including shipping in the USA. I will offer a nice discount if someone want to pick up in Houston, TX. For faster response you can call or text at 832 647 2347.
  2. aceinthesky
    Pearland, TX
    387Coins
  3. aceinthesky
    Pearland, TX
    387Coins
  4. aceinthesky
    Pearland, TX
    387Coins
  5. aceinthesky
    Pearland, TX
    387Coins
    Rig is sold
  6. Pit
    30,490Coins
    closed
Thread Status:
