Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    :grin:grin:grin
    No, terrible pilot!!! Perhaps the worst!!! :grin
    I bought Dirt Rally one year ago, but I never played it (except for a few short tests) because I was waiting to finish the rig!
    Now the sim is almost over, I hope to learn a little bit! o_O ... I will not have more excuses :D
    @yobuddy, SimTools is fantastic!!! Thanks again!!!:cheers
  2. yobuddy
    51,186Coins
  3. Faldri
    Faldri 2dof motion
    South korea
    117Coins
    Help me ..... when run dirt 4 game there is error information like picture below
    152,541Coins
    +11,085 / 56 / -2
    @Faldri the path for patching Codemaster games for motion differs, depending on it being a 32bit or 64bit version of Windows.
    32bit is patched to the game install path.
    For example 64bit Dirt Rally is patched to C:\Users\Your_User_Name\Documents\My Games\DiRT Rally: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
    Also make sure your computer language is set to English local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    If the problem persists reinstall .Net
  5. Faldri
    Faldri 2dof motion
    South korea
    117Coins
    I have patch the same as that .... maybe because I use 1 laptop.....
    Game also i installed in hdd Does it matter because the storage in C is full....
    152,541Coins
    +11,085 / 56 / -2
    You have what system, 32 or 64 bit, and which path did you patch?
    Did you run the game before patching?
    Have you changed your language settings?
    Have you reinstalled .Net?
    While the game can install elsewhere it will store some information on the C drive.
  7. Faldri
    Faldri 2dof motion
    South korea
    117Coins
    I have system 64bit....
    I've been patching......I've also run games before patching.
    How to reinstall net.
    Please help me
    152,541Coins
    +11,085 / 56 / -2
  9. Faldri
    Faldri 2dof motion
    South korea
    117Coins
    Thank you very much.....It turns out the problem is because the language I used before korea Now it can be without problems.....How to set the correct tuning center (MAX/MIN
    152,541Coins
    +11,085 / 56 / -2
    Great, that is good news :thumbs
    Can you please start your own project thread here, tell us a bit about your simulator and post your configuration and any other questions you may have on it: https://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
  11. Faldri
    Faldri 2dof motion
    South korea
    117Coins
    Thank full
    ..... If there is time i will post
  12. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    whats about GAME VIBE?
  13. Guilherme Bastian
    Guilherme Bastian New Member
    Brazil
    151Coins
    Guys,
    If I already have a lifetime license for simtools 1.3, will I need to buy another license for version 2.1? I installed it and it shows as a Demo.
    152,541Coins
    +11,085 / 56 / -2
    SimTools 1.3 was free, there were no paid licenses. I think you are confusing the new SimTools 2 licenses with the Xsimulator lifetime membership, with the latter being about access to plugins, see here for details about the relationship: https://www.xsimulator.net/community/faq/simtools-and-xsimulator-partnership-explained.275/
    Criteria apply but the DIY SimTools 2 licenses is available for free if you meet the prerequisites, see here for what the conditions are and how to apply: https://www.xsimulator.net/community/faq/request-a-free-diy-simtools-2-0-license.262/
    If you don't qualify for the free DIY SimTools 2 licenses or want additional functionality then yes you will need to buy a SimTools 2 license: https://simtools.us/license/
  15. ilbiga
    Network Engineer
    103Coins
    Hello to all. Yesterday I finally did a short test (in short I will be able to publish updates on my project ...) but a strange thing happened. I tested Project Cars and realized that some effects were too intense.
    Exiting the game, lowering the values in the Axis Assignments section and restarting the game.
    At this point all the effects are reversed and with a greater intensity!
    I did a test with Assetto Corsa thinking that it was a general issue but Assetto Corsa was ok.
    At this point I had reverse all effects in Project Cars by selecting the relative check boxes in Axis Assignments and everything has returned normal. :think
    This thing happened to someone else?:confused:
    Is it a SimTools bug or my system bug?o_O
    Thanks!!!
  16. noorbeast
    152,541Coins
    +11,085 / 56 / -2
    What are your system language settings? You should set them to English Local for SimTools: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
  17. paulopsx2
    brasil
    647Coins
    im using here o PC and all its ok. some packages on download section, dont represent EXACTLY movements on our SIMS. A DOF platform is a CUSTOM toy.. Some individual settings are unique and different for each.
  18. ilbiga
    Network Engineer
    103Coins
    @noorbeast: thanks !!! I did not remember this bug! Time ago I formatted the PC and I forgot to re-execute this setting! :thumbs
    @ Paulopsx2: The problem is not a game or another, but suddenly a game that worked perfectly stopped working. Thanks to @noorbeast I solved the problem... :)
    See you soon!!! :cheers
  19. paulopsx2
    brasil
    647Coins
    Interesting... my system is pt br... i dont have this problem. But ok... happy for.you rs
  20. George Dobransky
    Hungary
    - 43Coins
    Hi guys,
    I just installed 2.1, but at output testing there are only strange movements.
    With 2.0 it is still OK. The settings seems to be the same...
    Any ideas?
    George
