SilentChill
EVE Valkyrie Plugin CL1163233:LIVE
EVE Valkyrie
  1. SilentChill
    20,598Coins
    SilentChill submitted a new resource:
    EVE Valkyrie - EVE Valkyrie
    • Like Like x 5
    • Winner Winner x 3
    153,039Coins
    +11,116 / 56 / -2
    I have never bothered to install Valkyrie, even though it was free with the Rift, now I have a compelling reason to do so!
  3. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    Wow, that's great! Been long time since I played this, worth reinstalling :)
    Also, there is another nice little spacesim out for VR - Everspace. Currently it diverted my attention even from Elite.
  4. ferslash
    ferslash Active Member
    4,798Coins
    @SilentChill
    how long did it take you to learn how to make profiles?
  5. SilentChill
    20,598Coins
    I don't understand what you mean ? How long to learn how to make a plugin you mean ? Or how long to find memory locations to make a plugin ?
  6. Sym4d
    Sym4d New Member Gold Contributor
    - 156Coins
    Can I use this plugin on Oculus store?
  7. SilentChill
    20,598Coins
    Yes , that's the only place you can get the game isn't it ?
    153,039Coins
    +11,116 / 56 / -2
  9. SilentChill
    20,598Coins
    Ahhh in that case I need to change the title unless someone can try the plugin with the steam version to let me know if it works or not
  10. Sym4d
    - 156Coins
    I registered the plug in and tried to use it on oculus rift, but it didn't work. Are there any solution?
  11. ferslash
    4,798Coins
  12. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    Very nice plugin! Works on Oculus Home version of EV with zero problems. Even renewed my interest in the game a bit :D
    Thanks, SilentChill! If you consider adding surge at some point, that would be totally awesome :rolleyes:
  13. Tummie555
    Tummie555 New Member
    - 27Coins
    Unfortunately I'm having the same issue. Eve version 116..... Oculus home edition. Installed plugin through pluginupdater, run game manager as admin, patched successfully, banner turns blue when game is running, no movement. Rig works with all other games through simtools.
    153,039Coins
    +11,116 / 56 / -2
    Can you please post pictures of all of your settings and verify if data shows in the top of the Tuning Center.
  15. Tummie555
    - 27Coins
    Hi Noorbeast, thank you for the quick reply, there's no data in the tuning center. 20170715_122705.jpg 20170715_122707.jpg
  16. noorbeast
    153,039Coins
    +11,116 / 56 / -2
    Try unpatching, run Game Manager as the normal user and patch again.
    Was EV run fir before patching?
  17. Tummie555
    - 27Coins
    I unpatched, run game manager normal, patched again. Get error (attached picture). I follow the instructions in the error. Gamemanger reacts normal after because it detects the game (from green to blue, back to green after exiting game).
    I als tried: remove patch, delete plugin, delete Eve Valkyrie, restart computer, install Eve Valkyrie, start game, fly for a while, stop game, install plugin, patch game through normal user, follow error instructions, game mangers successfully detects game, still no motion, tuning center: all zero's
    P.s. I just bought Eve Valkyrie today, because they released a big update 13 July..
  18. noorbeast
    153,039Coins
    +11,116 / 56 / -2
    So have you tried manually copying the file @Tummie555?
  19. Tummie555
    - 27Coins
    Yes I followed the instructions in the error: I copied both the files manually into the simtools installation directory: C:/program files (x86)/simtools
    (The copying works fine, but the problem isn't solved)
  20. SilentChill
    20,598Coins
    If they updated the game I will need to update the plugin, its not on my radar as I never play it. I will try and have a look
