Newbie wanting to build a 2 dof with traction loss
Discussion in 'New users start here - FAQ' started by Risf-nz, May 28, 2017.
  1. Risf-nz
    Risf-nz New Member
    Hamilton nz
    61Coins
    3DOF, DC motor, Arduino, JRK
    Hi there
    am new to this forum and wanting to build a 2 dof with traction loss
    please see a list of item which am thinking of using to complete the build
    Adrunio Mega
    PSU – HP DPS-600PB 575W
    http://www.trademe.co.nz/computers/...upplies/power-supplies/auction-1330951261.htm
    Motors will be Worm Drive Motor & Gearbox 12V
    https://www.bgts.co.nz/12V-24V-DC Motors-DC Forward reverse controllers/styled-10/index.html
    not sure which will be the best option
    this
    Worm Drive Motor & Gearbox 12V12 Volt worm gear drive motor and gearbox
    Output Speed 150 - 160 RPM at Gearbox
    12v No Load Current: 1.8 Amps
    On load current 9 - 12 AmpsWorking Voltage: 12V
    Rated Torque: 30 - 45 Nm (Newton Meters)
    Gear Ratio: 25:1
    Net weight: 2.3 Kgs
    Power: 180W
    Weight capacity 40Kg12MM shaft hole size that complete from side to the other[​IMG]
    or this type?
    Single Shaft worm Drive 12V Right or Left Drive12 Volt Single shaft worm drive motor with or without electric brake.
    Ratio 50:1
    Motor RPM 5300
    160 Watts, 150 Watts
    Shaft RPM 100, 68, 60.
    Please ask if you need outside this range
    Also have this model in 71mm Diameter motor size [​IMG]
    And what motor drivers should I use the monstermoto?
    thanks for the help and i will post pics and info regarding my project :)
    152,391Coins
    +11,076 / 56 / -2
    The motors linked would suit traditional rig designs like a shoulder mount with traction loss.
    Your choice of control is JRKs, Monster Motor or Sabertooth, the FAQs have details covering each: https://www.xsimulator.net/community/faq/
