Bug Non standard install location....
Discussion in 'SimTools Pro & Entertainment Version' started by traveltrousers, May 30, 2017.
  1. traveltrousers
    traveltrousers Active Member
    Timbuktu, Tombouctou, Mali
    890Coins
    Most games work but the few that require you to copy the wow64 dll wouldn't patch properly or pick up the data from Eve and Elite until I reinstalled simtools to it's standard directory (I had it in C:/ProgramFiles/Simtools2.1)
    So, a frustrating hour or so but it seems ok now.
  2. SilentChill
    20,596Coins
    Yes been a problem that I had honestly forgot about
    @yobuddy is there any chance you could incorporate the GetBaseAddress.dll and wow64.dll in the next update to Simtools so they get installed at the same time ?
    No one would have a problem with the dll's not being in the correct place for the 64bit memory hooked plugins :)
  3. traveltrousers
    890Coins
    The wow64 file gets installed, but it's 42k or so, the Elite replacement is only 9k so that's also an anomaly....
  4. SilentChill
    20,596Coins
    Hmm never looked at the size, don't know why they are different.
  5. yobuddy
    51,239Coins
    @SilentChill ,
    That would make it easier for sure.
    Where does the files (GetBaseAddress.dll and wow64.dll ) come from.
    I just need to check their licenses to make sure I can include them in the next release.
  6. yobuddy
    51,239Coins
    wow64ext.dll is already included, is that different from wow64.dll?
  7. yobuddy
    51,239Coins
    My guess is the path is hard coded in the plugin itself.
    For future plugin writers, when installing SimTools, it creates a Path.ini file in this folder.
    "C:\Users\(you user folder)\AppData\Local\SimTools"
    This way any app can get the location of SimTools when needed.
  8. SilentChill
    20,596Coins
  9. yobuddy
    51,239Coins
    So we just need GetBaseAddress.dll added I think.
    Can you think of anything else that needs added?
    It there also a 64 bit version of GetBaseAddress?
  10. SilentChill
    20,596Coins
    There is just the one that we have now.
  11. value1
    15,082Coins
    Getbaseaddress is only needed because of non-64bit app. There's no need for a 64 bit dll by definition ;)
  12. yobuddy
    51,239Coins
    LOL :blush
  13. Neman Ahmed
    Neman Ahmed Member
    Automation Engineer
    Karachi, Pakistan
    163Coins
    3DOF, AC motor, Arduino, Motion platform, 6DOF
    do you have to put wow64 dll in system32?
  14. value1
    15,082Coins
    Put it into your Simtools installation directory.
  15. lysa elec
    lysa elec LYSA ELEC
    - 20Coins
    here the error message when i open simtool with starwars squadrons pluging
