Question some question about after register
Discussion in 'SimTools Pro & Entertainment Version' started by Meawto, May 28, 2017.
  1. Meawto
    Meawto Sorry for bad English ;'(
    Thailand
    - 336Coins
    i just buy pro version and have some question about License Key
    if i'm format my PC. will i lose my license ?
    because sometime if i have problem with my PC i will format and reinstall my windows
    can i deactivate my license and activate again ?
    now i use simtools 1.3 and going to activate my new key for simtools 2.1 ,and my pc have some problem with my windows port (win 10 problem :() but i have my work has to finish in next month and i want to try simtools 2.1 version.
    thanks
    Nathkit
    (grefroceman@hotmail.com)
    hug:hug:
    152,391Coins
    +11,076 / 56 / -2
    You can reactivate SimTools 2 with the Registration app once you reinstall Windows, just keep the registration number safe.
    If you ever need to you can also look up your SimTools license number, just log into SimTools.us: https://simtools.us/your-account/
    Use the email you purchased the Licenses with, and if you don't have a password, click reset password.
    Just to be clear you can't run Simtools 1.3 and 2.1 on the same computer. Before you remove 1.3 you can backup this folder by making a zipped copy in case you ever want to use 1.3 again - C:\Users\(Your User Folder)\AppData\Local\SimTools
  3. Meawto
    Thailand
    - 336Coins
    thanks you @noorbeast hug:
  4. Meawto
    Thailand
    - 336Coins
    one more question sir. if i plan to sell motion sim in thailand for private use
    can i use the same email as i use for myself for my customer registration ?
    • Disagree Disagree x 1
    152,391Coins
    +11,076 / 56 / -2
    No the EULA precludes that. A separate Pro License is required.
  6. Meawto
    Thailand
    - 336Coins
    so... i must use customer email when i buy simtools pro. version ?
  7. yobuddy
    51,114Coins
    I think what @noorbeast was pointing out, is that you use one License per Sim setup.
    (In other words, you don't use the same license you already used.)
    But if a company buys a Pro license for their customer, then yes, the customer uses the companies email for registering.
    (This way the company can pull up all of their purchased license on SimTools.us at any time.) :thumbs
  8. Meawto
    Thailand
    - 336Coins
    thanks @yobuddy
  9. Djules
    Djules New Member
    - 175Coins
    DC motor, Arduino, 4DOF
    Hello
    I can notactivate my license, I have reached the limit number, yet I have a pros license?
    I had to reinstall several times my pc following viruses.
    What can I do??
    Thank you in advance for your answers
    152,391Coins
    +11,076 / 56 / -2
    PM the SimTools developer @yobuddy.
  11. Djules
    Djules New Member
    - 175Coins
    tanks noorbeast
