2DOF Motion Platform
Discussion in 'DIY Motion Simulator Projects' started by ilbiga, May 12, 2015.
  1. matthew loomis
    matthew loomis Member
    rochester,ny
    603Coins
    I see you are using an arduino with a sabertooth. What sketch are you using? I use this one. You should tune your motors at full voltage. Use the the smc3 tools to adjust pid settings and power levels. I had mine turned up as far as possible at first but I had heat buildup and a jerky ride. Lowering my p and max power to only what was necessary made for a much more comfortable ride and cool motors.
    Center of gravity is also very important for a good tune. I set mine off just enough to always keep everything in tension instead of shifting back and forth from tension to compression. After that I was able to eliminate dead zone and drop I to zero.
  2. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Hi and sorry for the delay. First of all thanks for the advice.
    I use this sketch https://www.xsimulator.net/communit...bertooth-using-simplified-serial-working.136/ and I'm fine apart from the speed problems I've mentioned in the past.
    Sorry for the question :confused: : what are the SMC tools?
    Unfortunately I have some problem of barycentral due to various modifications being made and I am trying to circumvent some gimmicks (eg adding springs ...).
    Tomorrow I should be able to post a couple of new photos with some updates.
    Thanks again!:thumbs
    153,830Coins
    +11,151 / 57 / -2
  4. ilbiga
    Network Engineer
    103Coins
    Thanks so much! I did not know it!! I will use @matthew loomis advice as soon as I have some time! :thumbs
  5. ilbiga
    Network Engineer
    103Coins
    Finally some little update: added bodyshaker and amplification system !!! :)
  6. ilbiga
    Network Engineer
    103Coins
    Adding preload springs to balance monitor weight ...
  7. ilbiga
    Network Engineer
    103Coins
    Added support for flight simulations peripherals
  8. ilbiga
    Network Engineer
    103Coins
    ... Vibe update in progress... :grin
  9. ilbiga
    Network Engineer
    103Coins
  10. ilbiga
    Network Engineer
    103Coins
    Small update... integrated subwoofer...
  11. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    where did you find the plate of steel for the weld? ive not sure what direction to be looking, ive looked at a lot of place and stores but they all have sheets to thin.
  12. ilbiga
    Network Engineer
    103Coins
    Hello @Christopher.j.elliott .
    Sorry, which "plate of steel for the weld" you refer to???
    I did not understand the question... Forgive my poor English! :cool:
  13. ilbiga
    Network Engineer
    103Coins
    Some details are still missing, but we are starting to be at the end ... :)
  14. ilbiga
    Network Engineer
    103Coins
    Another small update (in progress...):
    Custom Keyboard (to substitute macro commands "Up/Down/Left/Right + Esc/Enter") and predisposition for Sequential Gearshift and Handbrake:
  15. ilbiga
    Network Engineer
    103Coins
    Game Vibe 3d update in progress ...
  16. ilbiga
    Network Engineer
    103Coins
  17. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    Thank you , VeryNice
  18. ilbiga
    Network Engineer
    103Coins
    thanks to you for the compliments. Over time I made many changes and in the end I had never published the results obtained! :thumbs
