One Motor or Two
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by terry wells, Apr 7, 2014.
  1. testlab
    testlab New Member
    33Coins
    Добрый день. Я использую схему модe2 . После прошивки , никакой реакции. Должен ли реагировать мотор с этой прошивкой на положение резистора?
    _____________________________________________________________________________________________________________________________
    Good afternoon. I use the scheme mode2. After flashing, no reaction. Should the engine to respond to this firmware to the position of the resistor?
  2. masterhoo
    masterhoo New Member
    Peru
    370Coins
    @bsft, so in other words if I find 24V motors only, what type of motor drivers would be recommended? The Sparkfun Monster allows 16v max.
    152,385Coins
    +11,076 / 56 / -2
    You could use a Sabertooth to drive both motors, see the FAQs for code and wiring details.
  4. Krisie300
    Krisie300 Student Engineering
    Netherlands
    146Coins
    Hi! I think I have a problem with the motors, cause the buzzer of the multimeter makes noise!
    So I've opened the motor but I can't see where it is attached to the body of the motor. The problem is that the motors don't turn in full speed backwards and when I put it in backwards the motor just stops turning after a little while. So here are a couple of photo's and a video.
    Hope someone can help me!
