Question DOF Reality - Roll & Pitch seem to be swapped.
Discussion in 'SimTools Pro & Entertainment Version' started by Shawn Alred, Jun 22, 2017.
  1. Shawn Alred
    Shawn Alred New Member
    Alabama
    299Coins
    I purchased a DOF Reality second hand and I'm finally getting time to set this thing up.
    I followed the directions and when I get to the output testing portion it seems that when I slide the pitch bar I get roll and when I slide the roll bar I get pitch. Traction Loss is working fine. I haven't made it past that point yet, I spent an hour last night trying to see if I was missing something obvious.
    152,385Coins
    +11,076 / 56 / -2
    It would help if you post pictures of your settings, it sounds like you have the Dir allocations in Axis Assignments messed up.
  3. value1
    15,050Coins
    So why don't you just swap them?
  4. Shawn Alred
    Alabama
    299Coins
    I'm not comfortable at all with this software yet, it's brand new to me and I don't want to screw anything up.
  5. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    We need the axis assingment page as well. The little orange (when checked)dir box controls the motor direction
  6. Shawn Alred
    Alabama
    299Coins
  7. PiaMan
    607Coins
    My motors are mounted such that i need one in each direction for pitch and the same for roll. You willbeed to test whether on or off is correct. Id start by switching the boxesso the dir boxes in roll look like you pitch and vice versa. Also start with one effect first. Get the motion right there. Pitch surge and heave should look the same. Roll and sway will have one opposite
  8. Shawn Alred
    Alabama
    299Coins
    Fixed. I picked "P2" and output test had everything working correctly. Thanks everyone.
  9. Neman Ahmed
    Neman Ahmed Member
    Automation Engineer
    Karachi, Pakistan
    163Coins
    3DOF, AC motor, Arduino, Motion platform, 6DOF
    I want to know the solution to the problem, so can you tell me what is "P2"
  10. Terry Mercer
    Terry Mercer New Member Gold Contributor
    Thailand
    263Coins
    Hi Shawn I also have a 3 DOF dof reality unit with traction loss and Im suffering the thing?
    I have writen to DOF Reality to ask for the exact settings as its not shown in there instructions!
    Cheers Terry
    152,385Coins
    +11,076 / 56 / -2
    In Axis Settings the Dir boxes being checked orange or not defines which way each axis moves, this is the movement they should conform to in Output Testing: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    Once you get that sorted take your time and work through and learn the steps to creating and refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    It also helps if you start your own thread and post pictures of all of your settings.
