Question OSW: Connection, pushbuttons, accelerator, brake on Simucube
Discussion in 'Direct Drive Wheels' started by Racing, Jun 26, 2017.
  1. Racing
    Racing New Member
    España
    305Coins
    Hi. I have a simucube that I bought 10 days ago.
    I want to connect buttons to raise and lower gears, or for other options.
    I want to connect potentiometers for accelerator, front brake, rear brake.
    I have seen this page:
    Http://granitedevices.com/wiki/SimuCUBE_connector_pinouts
    Http://granitedevices.com/wiki/SimuCUBE_wiring_overview
    Viewing this page as I do not know much about electronica, I do not know how to connect them.
    I would like someone to tell me graphically how they would connect. And as it is configured in simucube software.
    Do you recommend directly buttons, potentiometers to simucube or use a leo bodnar plate or similar?
    A greeting.
  2. Racing
    Racing New Member
    España
    305Coins
  3. Racing
    Racing New Member
    España
    305Coins
    I self-answer my message. JEJEJE.
    This is the answer from the Simucube manufacturer:
    Elecrically, a potentiometer looks like this (note that SimuCUBE uses 3.3V, but this can be ignored if you just follow the wiring example and connect to the 3.3V pin).
    and a button can be wired between the X12 pin 8 and any other pin on X12.
  4. Racing
    Racing New Member
    España
    305Coins
    Picture of the previous message
  5. Racing
    Racing New Member
    España
    305Coins
  6. baykah
    baykah Active Member
    Toulouse - France
    414Coins
    But I don't think you want to send back 5V to the sim cube ...
  7. Racing
    Racing New Member
    España
    305Coins
    Do not connect 5V to simucube.
    After the manufacturer gave me that instruction corrected me today and told me not to connect it to 5V
    I'll delete the whole post.
  8. baykah
    Toulouse - France
    414Coins
    Wait, you just need to do a divider with two resistor ?
    Maybe with an AOP follower at the end of the potentiometer ?
  9. Racing
    Racing New Member
    España
    305Coins
    Manufacturer reply:
    Arduino's and Bodnar circuits use 5 V microcontroller, where as the STM32F407 on SimuCUBE operates at 3.3 V. That is the main reason.
    You can try to use that sensor you linked. Most of these sensors work correctly with slightly lower operating voltage.
  10. Racing
    Racing New Member
    España
    305Coins
    What do they advise?
    To connect a pedal and keypad use the Simucube or use Leo Bodnar
