How to pick out the right valves?
Discussion in 'Pneumatic equipment - outdated' started by yobuddy, Mar 8, 2007.
  1. yobuddy
    51,260Coins
    I know I would like to go with 50 mm (2”) bore and 300mm (12”) stroke cylinders. But I’m confused as to how to size up proper valves? Is there a way to figure it out or something I should be looking for, like CV value or something?
    I picked up this manifold and valves but it just looks way too small :roll: , any help would be greatly appreciated!
  2. yobuddy
    51,260Coins
    Looking thru stuff for the auto industry, I have found valve manifolds made for air shocks and struts and there even 12v. I don’t think the price is too bad either at 175$ USD. Just wondered if anyone had any thoughts?
  3. Snaipa
    Snaipa New Member
    0Coins
    You can get the original rock'n'ride valves for much less money
  4. yobuddy
    51,260Coins
    Id sure like to know where? here in the states there is no rock n ride - and the one valve set I have seen for a rock n ride was 299$ USD.
  5. yobuddy
    51,260Coins
  6. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    I studied their homepage, but they have not enough informations about the valves.
    They should do it but dont blame me if they dont. Cause I dont know it for sure.
    The best would be, you send an email to them. Ask them if the valves have a closed center position and about the response time. They seem to be like the Festo 5/3 but I cant say anything about the air-hose connection diameters as they are in inch.
    Afaik, Renoboss uses SMC parts, but for some reason he disappeared from this forum and cant help us concerning this matter.
    regards
    BTW, if they do not fit you could put them, with some air jacks, in your car and jump with it through your neighborhood ;-)
  7. yobuddy
    51,260Coins
    Thanks for all your help egoexpress!
    LOL - my neighbors would love me
    What kind of response time do the original valves have?
    I believe all the ports on the manifold are about .95 cm; I’m thinking I will probably have to slow the released air down a little.
    I'll give them a call tomarrow
    Thanks again!
  8. egoexpress
    421Coins
  9. egoexpress
    421Coins
    hmm, they dont seem to be the manufacturer of the valves. Imho they just put a tag with their logo on them. They seem too pricey.
    But, to be honest, I dont know the price of the Festo MEH 5/3 G 1/8, as well. Snaipa wants to check it out for us ;)
  10. egoexpress
    421Coins
    BTW, perhaps it would be cheaper to buy it without manifold block. Imho you dont need it absolutely. But dont know it for sure.
  11. yobuddy
    51,260Coins
    Thanks egoexpress!
    My head hurts from reading pdf's on valves lol
    Thanks for looking into the valves Snaipa!
  12. yobuddy
    51,260Coins
    I called on the valves today at airridepro.com and the sales rep confirmed they are center closed valves, but he had no data on response time.
  13. egoexpress
    421Coins
    center closed is good
    The rest seems ok as well, only the response time would be important. Either he dont know it for sure, or he doesnt wanted it to say, because the specs are too bad ;)
    Why havent you asked him about the original manufacturer? :mrgreen:
    Perhaps you should force him to investigate it. Cause its much money to waste if they dont fit.
    The Festo ones are these:
    http://catalog.festo.com/enu/asp/Defaul ... 3139&L=001
    Part number:
    173139
    regards
  14. yobuddy
    51,260Coins
  15. egoexpress
    421Coins
    Another member here bought a complete valveblock of them for 40 Euros at ebay.
    Perhaps luck!? You could try to observe ebay a few days. Or by the ones from the shop you linked here. But ask for the response time before you buy them
    regards
  16. egoexpress
    421Coins
    Here in Germany you can buy a product, and within 14 days you can send it to back and you get your nickel back ;) lol hahaha nickelback hrmm, too much wine ;)
  17. yobuddy
    51,260Coins
    You mind checking these out egoexpress?
    These valves look decent and they are available online.
    They are not cheap, but they are cheaper that the festo one’s referenced in this thread, at least for me here in the states.
    • Cv: 1.0
    • Port Sizes: 1/8 & 1/4 NPFT
    • 5 ported, 2 & 3 position, 4-way, spool & sleeve
    • Flow Capacity: 46 SCFM @ 80 PSIG / 985NI/M @ 6 Bar
    • O.P. Range: 28 Hg. Vac. to 150 PSIG / Vac. to 10 Bar
    • Temp. (Ambient): -10 F° to +115 F° / -23 C° to +46 C°
    • Non-lubricated or lubricated service
    • Switch on: 10ms / Switch off: 35ms
    http://www.aircylindersdirect.com/webap ... figuration
    should I get them with 1/4 NPTF ports since the cylinders I will be using have 1/4 NPTF connections?
  18. egoexpress
    421Coins
    These could be suitable.
    If I was you, i'd prefer the 1/4 with air hose adapters. If you want to use bigger cylinders some day, you'll have the right valves.
    And they have the same price anyway
    regards
  19. yobuddy
    51,260Coins
    Thanks egoexpress, you have been a great help! 8)
    you mean something like this:
    1/4 Tube - 1/4 NPTF
    Thanks again!
  20. egoexpress
    421Coins
