Lesson How to Register SimTools 2.0
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Feb 4, 2017.
  1. yobuddy
    51,564Coins
    Here is a step by step on how to register SimTools v2.
    1) Launch “SimTools Registration”.
    2) Enter the email address you purchased your license with into the “Email Address” text box.
    3) Enter the license you received into the “License Key” text box.
    4) Click “Activate License”.
    That’s it, enjoy SimTools v2! :thumbs
    153,992Coins
    +11,162 / 57 / -2
  3. RandomCoder
    Control Engineer
    1,674Coins
    You have a motion simulator using SCN5's but can not afford SimTools? Seems like you may have made poor design decisions? Through participation here on the forum I believe you can earn virtual coins that will enable you to make the purchase, it might take a while though ;)
  4. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    i don't think he has a sim. he has listed every type of interface as a sim and only joined today
    • Old Old x 1
  5. poman
    poman Active Member
    154Coins
    i just installed V2.1 after competely uninstaled V1.3, i got my registration code for the DIY version, but when i open Simtool registration from the shortcut menu, after a few sec it says that the program as ceased of functionning ??? tks
  6. yobuddy
    51,564Coins
  7. poman
    poman Active Member
    154Coins
    hey @yobuddy ,
    i am using free avast
    yes i did say yes to remove old files. I spent the hole day yesterday to update windows and i checked that ALL .NET update where succesfull.
    tried the .NET fix tool without succes.
    Here is what i got from the ''Cease of functionning'' window after i let it run to try solve the problem...if that can mean something to somebody more knowledgeable than me :)
    Fichiers aidant à décrire le problème(files to help describe the problem) :
    C:\Users\Daniel\AppData\Local\Temp\WER9B28.tmp.WERInternalMetadata.xml
    C:\Users\Daniel\AppData\Local\Temp\WERCF91.tmp.appcompat.txt
    C:\Users\Daniel\AppData\Local\Temp\WERD05D.tmp.mdmp
    I am a bit desperate to have to go back to V1.3 which i dont have Dirt 4 plugin ...never could run this new game i bought cause i cant stay on my rig static unless i make support for it...anyway
    TKS a lot in advance
    cheers
    153,992Coins
    +11,162 / 57 / -2
    Have you tried disabling Avast @poman?
  9. yobuddy
    51,564Coins
    @poman Notice how all the files your having problems with are in the temp dir?
    You may have a virus/malware.
    And you probably also have some corrupted system files.
    Please follow these steps.
    1) Download CCleaner.
    https://www.piriform.com/ccleaner/download
    the free version is fine.
    - Run the cleaner.
    2) Download Malwarebytes (free).
    https://www.malwarebytes.com/mwb-download/
    - Run a full scan, remove the junk.
    3) Now update and run your avast.
    - Run a full scan of Avast and remove the junk.
    4) Open CCleaner again.
    - Run the cleaner (again).
    - Run the registry cleaner.
    5) Now run check disk on the drive
    Open "my pc"
    Right click on the drive to check and select properties.
    Click the tools tab.
    Click error checking.
    (Put check marks in both options - if asked) and click scan.
    Most likely will ask you if it can run on the next startup - say Yes and reboot.
    6) Try out SimTools!
    (After all this I would defrag overnight too, if you don't have a ssd)
  10. poman
    poman Active Member
    154Coins
    humm tks for the time to write all this procedure :)
    will try this soon and keep you posted of the result...tks
  11. poman
    poman Active Member
    154Coins
    It took a while but got it done and unfortunatly didnt solve the issue, still getting same kind of result but with different file numbers in the temp folder, guess they are invisible files cause i went in there and couldnt find them...also tried to dissable avast and no success either, the only thing i can think of is that during the windows updates i did before your procedure, there was a few updates that were unsuccessfull and i believe some were related to framework, i will have a friend help me on that, but if you have a way of bypassing the registration window or force it to show...i am all ear, and that could be through PM
    tks again for help...greatly appreciated
  12. yobuddy
    51,564Coins
  13. poman
    poman Active Member
    154Coins
    @yobuddy
    After some verification, found out i had a few bad sector on my HD and they couldnt get fixed, so i decided it was time to upgrade to windows 10 and do a completely new install(was having all sorts of issues), and obviously it solved the problem, thanks a lot for help :)
  14. yobuddy
    51,564Coins
    If your HDD is starting to drop sectors, I would think about a new HDD buddy.
    Although reinstallation will fix it in the short term, My guess is it wont be long until it starts dropping more sectors. (slow HDD death).
    Please make sure you have backups going just incase buddy!
  15. JayceTeng
    JayceTeng New Member
    非政府组织的专业软件测试员
    - 86Coins
    2DOF, DC motor, SCN6, Arduino, Joyrider, Motion platform, 4DOF, 6DOF
    Backup 1.3 - Before you remove 1.3 backup this folder by making a zipped copy - C:\Users\(Your User Folder)\AppData\Local\SimTools
    Then if you ever want to go back, simply install 1.3 and replace this folder with the zipped copy about it.Can I use this Simtools 1.3 backup to Set Simtools 2.0?
  16. noorbeast
    153,992Coins
    +11,162 / 57 / -2
    Do a clean setup for SimTools 2.
  17. marko
    marko New Member
    finland
    146Coins
    I bought a diy license a year ago but after reinstalling Windows I can not find it anymore. where can i get it again?
  18. noorbeast
    153,992Coins
    +11,162 / 57 / -2
    You can look up your SimTools license number, just log into SimTools.us: https://simtools.us/member-login/
    Use the email you purchased the Licenses with, and if you don't have a password, click reset password.
  19. marko
    marko New Member
    finland
    146Coins
    it says There are no users registered with this email address :think
    and I bought it that's sure.
    153,992Coins
    +11,162 / 57 / -2
    You will need to PM @yobuddy for assistance, as he can access the records.
