Resolved DIY SIMULATOR: .net crash GMer, reinstall now not connected.
Discussion in 'SimTools Pro & Entertainment Version' started by SBDESIGN, Jul 9, 2017.
  1. SBDESIGN
    SBDESIGN some knowledge
    director
    125Coins
    2DOF, SCN5
    Hi folks.
    I have bee using sim tools 1.3 and recently 2.1 soon after release. 13/14 months in total.
    scn5 setup and windows 10.
    Everything has been smooth but recently when turning on pc i was getting a .net framework error and it said xml. issue. I found game manager to be the issue. I set it to open on start (why else am i powering pc)
    So I tried all framework downloads but windows always stated current is latest so wouldn't install. and all repair tools were used with o prevail.
    Next I copied and pasted files from appdata location to backup on my desktop.
    uninstall simtools
    reinstall
    tested if i could open, answer was yes without error.
    no settings, so copied my app data folders back across
    then ....same error
    uninstalled reinstalled
    copied game engine folder over, started and actuators worked as expected (work in test as well) and game manager loaded but no plugins.
    copied just iracing game plugin over and now that shows
    BUT Game manager states not connected.
    I then booted iracingbut still not connected.
    can anyone help?
    i can not remember for life of me, so i need to ask...
    when does it state connected?
    prior game load?
    game loaded?
    or when you click off of replay?
    just so i know what i'm testing.
    cheers
    sbdesign
  2. yobuddy
    51,665Coins
    Did you try this buddy?
    • Close all running software applications.
    • Go to Windows Start Menu -> Control Panel -> Add or Remove Programs or Program and Features.
    • Select Microsoft .NET Framework 4 Extended.
    • Click Change/Uninstall, Remove or Repair.
    • Select the Repair option, click Next.
    • The wizard will perform a repair on the .NET Framework installation.
    • It is suggested to restart the Computer.
    let us know SBDESIGN,
  3. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    firstly sorry for bad title, i read rules after clicking post so this should say DIY in front of title. Ill try and change.
    cheers yobuddy but 2 things...
    1. not getting that error but getting not connected
    2. these is no "Microsoft .NET Framework 4 Extended."
    all ms stuff is ms visual c ++
    was all working 6 days ago and i tried rolling windows back 10 days with o prevail either.
    damn since 4pm ive been free to race...typical.
  4. yobuddy
    51,665Coins
  5. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    1.... continued.......i mean after install and only coping iracing plugin and game engine settings back (i got .net error again if also copied full plugins folder along with game manager)
  6. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    Details
    Microsoft .NET Framework 4 is already a part of this operating system. You do not need to install the .NET Framework 4 redistributable. <A HREF="http://go.microsoft.com/fwlink/?LinkId=164207">More information</A>.
    Same or higher version of .NET Framework 4 has already been installed on this computer.
  7. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    ah ha,
    • extra step.... on the left column click turn windows feature on or off
    after i did this i unchecked all frameworks
    then rebooted
    now states connected....
    not tried game thought id put your mind at rest...didn't want you loosing sleep;)
    thanks again for super quick responses!
  8. yobuddy
    51,665Coins
    w00t!
    Nice work buddy!
    :thumbs
  9. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    update...
    all working with iracing
    fair few shutdowns and powerups happened in last 24 hrs and worked error free everytime.
    its like christmas again, i forget how good sim racing is.
    I'm now on skipbarber, after mx5 rookie,
    I'm struggling a little compared to mx5. Im not even competeing, last on grid etc... time for reading up me thinks.
    cheers again
  10. yobuddy
    51,665Coins
    w00t! :thumbs
  11. Mpmo
    Mpmo Member
    United Arab Emirates
    1,289Coins
    hey man, what do you mean by uncheck all frameworks..? what should i press here: https://imgur.com/a/RcqSt
  12. Mpmo
    Mpmo Member
    1,289Coins
  13. Mpmo
    Mpmo Member
    1,289Coins
    ohh sorry @noorbeast just saw your comment on the aerofly 2 thread, this is the problem i'm having. I'm hoping one of @yobuddy or @SBDESIGN answer :/
  14. yobuddy
    51,665Coins
    @Mpmo
    If you reinstalled win10, check to make sure you have .net 3.5 and below checked.
    I have 3.5 and 4.7 enabled.
    Sound like @SBDESIGN had something a bit different?
    Take care,
  15. Mpmo
    Mpmo Member
    1,289Coins
    yeah it is checked https://imgur.com/a/M9eQC
    but issue still persists
  16. yobuddy
    51,665Coins
    @Mpmo,
    You can post pics directly in your posts buddy.
    Just drag and drop them in.
    No need for offsite postings.
    Let me look at your link.
  17. yobuddy
    51,665Coins
  18. Mpmo
    Mpmo Member
    1,289Coins
  19. yobuddy
    51,665Coins
    I don't see anything above .net 3.5 on your list thou?
  20. Mpmo
    Mpmo Member
    1,289Coins
    yeah i have no idea.. maybe i should uninstall 3.5 and install the link you sent?
