DIY Playseat update with 2/3 DOF Arduino, MonsterMotor
Discussion in 'DIY Motion Simulator Projects' started by DirtDro, Jun 29, 2017.
  1. DirtDro
    DirtDro X-plane Rheinstetten
    213Coins
    Hallo Xsim,
    I would like to extend my DIY Playseat with 2 DOF. At the moment I have only a steel frame with kart seat and Thrustmaster RS500. I bought an Arduino and 3 Monster engine drivers. Now I'm looking for suitable engines with 12V and what else is missing.
    - Power adapter
    • Optimistic Optimistic x 1
  2. DirtDro
    213Coins
    153,001Coins
    +11,116 / 56 / -2
    What design do you plan to use, as that will affect what motors may or may not be suitable?
  4. DirtDro
    213Coins
    Wow thank you for your very fast answer!!
    First i want two Motors:
    Version a: under the streering
    Version B:at the back of the seat
    Driver gewicht 66 kg
    Options: new Sparco Seat Grid II 10 kg
    something like that:
    153,001Coins
    +11,116 / 56 / -2
  6. DirtDro
    213Coins
    Thank you.
    they have only 24Volt motors?
    I think monster moto can only 12V?
    153,001Coins
    +11,116 / 56 / -2
  8. DirtDro
    213Coins
    only this motor is in stock in UK:
    DC Brushed Geared Motor 150W
    Model: 90ZYT-199-12-MCP2-60:1 GH1485
    (12VDC, output speed 20RPM, 1.2Nm, gear ratio 60:1, Delrin gears)
    with position well be the best?
  9. DirtDro
    213Coins
    Hallo,
    now a few new parts have arrieved:
    - Arduino
    - Monster Motor
    - Sparco Race Seat
  10. DirtDro
    213Coins
  11. DirtDro
    213Coins
    Hallo,
    I have found on ebay this engine. Is it strong and fast enough?
    WG88BD82-3 Schneckengetriebemotor: 12V | 80W | 35/55U/min | max. 60Nm | M8 Welle
    Beschreibung:
    • Drehmomentstarker 12V Getriebemotor mit extra grossem Ø88mm Schneckengetriebe mit max. 60Nm Drehmoment. Leistungsstarker Gleichstrommotor mit 80W und Motordurchmesser von Ø82mm
      __
    • Drehrichtung Uhrzeigersinn (Drehrichtungswechsel durch Umpolung möglich)
    • Motortemperatur (Motorgehäuse) max. 55°C (bei hohem Drehmoment Start/ Stop betrieb notwendig)
    • Version: mit 3 Anschlussdrähten. Anschluss Rot/ Blau= 35U/min; Rot/ Weiss=55U/min
      (Ersetzt die Modelle WG88BD82-1/2)
    • 12-24V Betrieb möglich (max. Temperatur des Motorgehäuses beachten)
      _
    153,001Coins
    +11,116 / 56 / -2
    They look to be some type of wiper motor.
    They would likely work with a design that has a lot of leverage like a foot or shoulder mount, but they are not particularly fast nor as good as what was already recommended for the plan you had put forward, which is a knee mount design.
  13. DirtDro
    213Coins
    will this one be better? (from UK motioncontrol?
    Model: 73ZYT-145-12-MCP4-62/1-BZ-GH1436
    (12VDC, 135W, output speed 70RPM, 15Nm, gear ratio 62:1, bronze gears)
    (73ZYT-145-12-MCP4-62/1-BZ-GH1436) DC brushed geared motor is a stock item for quick delivery.
    Click here for 73ZYT-145-12-MCP4-62/1-BZ-GH1436 DATASHEET/DRAWING
    153,001Coins
    +11,116 / 56 / -2
    Yes I consider those would be better and they have been used by other members.
  15. DirtDro
    213Coins
    Thanks for your help @noorbeast.
    I will buy three of them and hope they will come before my holiday.
  16. DirtDro
    213Coins
    After i had place my order, my money come back, because Motors out of stock.
  17. DirtDro
    213Coins
    After my holiday, my simulator is making progress. I ordered 2 motors at Motioncontrol in Australia.
    320W 12V Worm Drive Transmission 50: 1 left and right.
    64 rpm, 27 A, 50nm 5,7 kg
    Welding of steel pipes has not worked so well.
    For the console I ordered 30 of my aluminum profiles and assembled.
    Greeting
  18. noorbeast
    153,001Coins
    +11,116 / 56 / -2
    Any further progress updates?
  19. DirtDro
    213Coins
    there is news:
    The engines were delivered very fast. Could pick her up directly at the customs office. Fee about 100 €
    In addition, I have ordered for the base frame 40er aluminum profiles and already got. Cardan joint is from a BMW 3 series. I also made some wood of the basic construction. In the box outside the support the electronics come in.
    The smc3 software and the arduino board are already working.
    Attached some pictures. Have vacation at the moment and hope I can get a long way.
    The software will now use x-plane instead of dirt.
    Greetings from Baden Württemberg
    Dirk
  20. DirtDro
    213Coins
    aktuelle Bilder: IMG_6346.JPG
