Problem with Visualizing game´s data extraction
Discussion in 'New users start here - FAQ' started by li278843672, Jul 15, 2017.
  1. li278843672
    li278843672 New Member
    117Coins
    hi guys.
    i arld finish my output texting,it's prefect.The Axis corresponds to an actuator,the actuator moving when i slide gently the slider with my mouse, as well the game patching is good, game manager is show my game running.im so exciting,it is almost done. but enter the game, my Axis do nothing the sliders isnot moving, and the virtual axis not showing any data. if u have time,pls tell me which part wrong, ty. :)
  2. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Are you assigned the axes for that game?
  3. li278843672
    117Coins
    it's assigned,but im not sure this is right or not:(
  4. li278843672
    117Coins
  5. li278843672
    117Coins
    151,467Coins
    +11,041 / 56 / -2
  7. li278843672
    117Coins
      148.7 KB
      655
    151,467Coins
    +11,041 / 56 / -2
  9. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Yeah that's right.
    I have tried it and it works well. Remove the patch and patch again, you should not have problems.
  10. li278843672
    117Coins
    i alrd change the patch path to C:, install the Dirt3 again. but still no working...
    Are there any other problem?:confused:
    151,467Coins
    +11,041 / 56 / -2
    What are your Interface and computer language settings?
  12. li278843672
    117Coins
    the interface i use JRK, and im from China.hug:
  13. noorbeast
    151,467Coins
    +11,041 / 56 / -2
  14. li278843672
    117Coins
  15. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Have you tried more games?
  16. li278843672
    117Coins
      171.8 KB
      619
      170.9 KB
      637
  17. li278843672
    117Coins
    the Dirt Rally not woring as well,pls help me check the patching path wrong or not?
      28.6 KB
      634
      1.1 MB
      689
      24.1 KB
      616
  18. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Documents/MyGames/Dirt3
    151,467Coins
    +11,041 / 56 / -2
  20. li278843672
    117Coins
    how about i try to use the 32bit machine, is the patch path same with 64bit in C: or just patched to the game install path, becos my C: almost full, and the other reason is my game download from Steam,the total game file cant be move to the C:, i tried move the postion and then game cant start.
