Motion simulator
Discussion in 'DIY Motion Simulator Projects' started by nasrollah, Jul 22, 2017.
  1. nasrollah
    nasrollah New Member
    iran
    252Coins
    Hello
    Good day
    I encountered a problem in making the simulator.
    The LFS game is associated with the simtools software, but I can not connect Arduino with the simtools software.
    That's why I send the Arduino configuration file to check if possible friends and fix the drawbacks if I can, and then go to other sections to solve the problem with friends.
    Communicate clip with the simtools software with LFS game
    No connection clip to the simtools application with Ardino
    152,373Coins
    +11,076 / 56 / -2
    Further information is needed.
    What code are you using with the Arduino.
    The difference from SimTools 1.3 to SimTools 2.0 in setup is that instead of axis defined like this <Axis1> it is now like this to designate grouping for a or b <Axis1a>
  3. nasrollah
    iran
    252Coins
    Hello
    Code I used for Ardino
    Code deleted by moderator
  4. nasrollah
    iran
    252Coins
    and
    I installed the cythmolos version
    SimTools_2.1
    152,373Coins
    +11,076 / 56 / -2
  6. nasrollah
    iran
    252Coins
    Hello
    Thank you for your guidance.
    By making the changes that you said, I could get feedback on the game in Ardino.
    I am sending it after preparing a Wiper motor and testing a film project.
    Thanks for the help
