Done Lurking
Discussion in 'DIY Motion Simulator Projects' started by exiledslinky, Jul 20, 2017.
  1. exiledslinky
    exiledslinky Member
    Edinburgh
    334Coins
    upload_2017-7-20_18-5-8.png upload_2017-7-20_18-6-1.png [​IMG]
    So far i have
    2x --jrk 12x12
    2x 200watt 50:1 motors actually have 6 of them lol
    psu 12v 500watt 40amp
    Shafts are from a Yamaha Virago and I believe a Honda NT500
    Going to build 2 different 2dof 1 seat mover and 1 chassis mover
    Links are simple motorsport adjustable light weight links
    Have larger ones for seat mover
    Just waiting on Aluminum Proile to show up for the base of the chassis mover.
    Been talking to the grand master eaorobbie To get this project going and Finally should be done middle of next week..
    So get ready for loads of How do i do this and how do i wire up that
  2. exiledslinky
    exiledslinky Member
    Edinburgh
    334Coins
    BUILD DAY IS HERE
  3. SilentChill
    20,598Coins
    good start :) however that UJ looks very thin ?? :eek:
  4. exiledslinky
    exiledslinky Member
    Edinburgh
    334Coins
    I assure you they are up to the task.. :p
    • Optimistic Optimistic x 1
  5. exiledslinky
    exiledslinky Member
    Edinburgh
    334Coins
    so was trying to figure out how to mount the jrks and cool them at the same time so decided to use my 3d printer and make a mount for both the fan sits above the jrks and so hopefully this works.
    Ive included the stl its for a 140mm computer case fan if u better the design please share
    may need spacers though
    [​IMG][​IMG][​IMG]
    153,039Coins
    +11,116 / 56 / -2
  7. exiledslinky
    exiledslinky Member
    Edinburgh
    334Coins
    Everythings wired ready to go.. Dam turnbuckles i got are to long so out tmrw to get some 12mm rod and some female rd ends
  8. exiledslinky
    exiledslinky Member
    Edinburgh
    334Coins
    ITS ALIVE!!!!!!!!!
    happier then a pig in S**t
    Thank @aoerobbie and Nick Moxley for all your help
    153,039Coins
    +11,116 / 56 / -2
    It is always such a relief and sense of achievement when you first get your sim fired up, well done :thumbs
    It is hard to tell from the angle but it looks like you could allocate a bit more sway.
