Question Game manager has an error.
Discussion in 'SimTools DIY Version' started by kjjcard, Jul 28, 2017.
  1. kjjcard
    kjjcard Member Gold Contributor
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    Hello.
    What I want to ask is that my GameManager has an error!
    I have confirmed that the motors in the GameEngine are moving.
    However, the angle of the motor was 0 to 90, not -90 to 90.
    I want to solve this problem.
    And I turned on the GameManager and turned on the GameEngine and the moment I turned on the game.
    GameManager will continue to run but the motion platform will not work.
    I am really embarrassed in this situation.
    one more I would like to ask again.
    I downloaded a game plug-in other than LSF
    Even if I put it on Simtool PluginUpdater, it is not added to the game list in GameManager.
    Do you have to buy licenses?
    Thanks for reading it.
    This article is being translated into Google translation.
    Because English is strange i am sorry,
    Thank read you everyone.
    154,580Coins
    +11,190 / 57 / -2
    SimTools 2 in Demo mode has a fully functional Live For Speed plugin included for testing puposes, but won't allow other plugins to be installed, for that you need a licence. Conditions apply such as membership duration and progressing and actual DIY build thread and project, but eligble DIY members can apply for a free SimTools 2 DIY license: https://www.xsimulator.net/community/faq/request-a-free-diy-simtools-2-0-license.262/
  3. kjjcard
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    Thank you very much for your reply.
    I am willing to purchase a license.
    But I think I should start LFS and buy it.
    Is this the information you need?
    Try uploading your photos.
    It would be great if quick answers came.
    Thank you.
  4. yobuddy
    51,676Coins
    Try this buddy,
  5. kjjcard
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    d
    Is changing the language to English a problem?
    154,580Coins
    +11,190 / 57 / -2
    I agree re the Language settings @yobuddy has indicated.
    It would also be useful to know how the actual hardware axis work, from your settings it looks to be two seperate axis. What configuration is your simulator and can you please post a picture of it.
  7. kjjcard
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    This is my motion platform.
    I will change to English and restart my computer.
  8. yobuddy
    51,676Coins
    Depending on where you are from, your local ascii table may only cover half of the needed traveled on your actuators.
    (meaning half the ascii table is missing)
    If you set the PC as I showed above, I know you getting the full ascii table as intended.
    Once I get all the apps out, I will go back and re-look this problem over.
    There is just so much to do still, and I try to do the stuff that covers the most people.
    But I won't be completely satisfied until I knock it out.
  9. yobuddy
    51,676Coins
    Looks like a nice simulator @kjjcard!,
  10. kjjcard
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    I am proud of my motion platform! HA HA!
    Fixed a problem with Simtool GameEngine.
    The motor works very well at -90 to 90 degrees.
    However, the problem with Simtool GameManager has not been solved.
    If you click Continue with this error message when you start the game, the motion platform will not move.
    Click Exit to quit GameManager.
    If you click Continue, this message will disappear several times.
    Contents of the first message.
    System.ComponentModel.Win32Exception (0x80004005): ReadProcessMemory 또는 WriteProcessMemory의 일부 작업만을 마쳤습니다
    at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId, Boolean firstModuleOnly)
    at System.Diagnostics.ProcessManager.GetModuleInfos(Int32 processId)
    at System.Diagnostics.Process.get_Modules()
    at SimTools_GameManager.frmMain.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.2101.1 built by: NET47REL1LAST
    Assembly Version: 0.2.1.0
    Win32 Version: 0.2.1.0
    CodeBase: file:///D:/3DF_Arduino/SimTools/SimTools_GameManager.exe
    xdFZySjlJvJuSyJCrKNFqiOVuiS
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.7.2046.0 built by: NET47REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.7.2093.0 built by: NET47REL1LAST
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Win32 Version: 4.7.2099.0 built by: NET47REL1LAST
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.7.2094.0 built by: NET47REL1LAST
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.7.2046.0 built by: NET47REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Game_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///D:/3DF_Arduino/SimTools/Game_PluginAPI.DLL
    System.Management
    Win32 Version: 4.7.2096.0 built by: NET47REL1LAST
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    LiveForSpeed_GamePlugin
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.0.0
    CodeBase: file:///C:/Users/JUNG/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    Microsoft.GeneratedCode
    enabled.
    For example:
    <configuration>
    </configuration>
    154,580Coins
    +11,190 / 57 / -2
    Given the characters in the error it seems that there are still language setting issues: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    Once you get the hardware working you will need to sort the Axis Allocations.
    The Dir boxes being checked orange or not determines which was an axis moves and a 2DOF can still simulate sway, surge, heave, roll and pitch. This is how SimTools normally expects each to move: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    Once the Axis directions are properly set you can create and refne motion profiles for each game, see here for the steps involved: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  12. yobuddy
    51,676Coins
  13. kjjcard
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    yes
  14. kjjcard
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    I now have a problem with the axes of the motion platform, and the moment I set the language.
    But there is still a problem with GameManager.
    Thanks for the link.
  15. yobuddy
    51,676Coins
    ReadProcessMemory & WriteProcessMemory are not functions in SimTools.
    So I wonder how its throwing these errors?
    Hmm..
    thinking...
    Are you able to update windows with the window updater?
    this error 0x80004005 is associated with a corrupt win updater is why I ask.
  16. kjjcard
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    I do not have any more windows updates left.
    Hmm ... I still do not know what the problem is.
  17. yobuddy
    51,676Coins
    Still thinking...
    Is it a new installation of win10?
  18. yobuddy
    51,676Coins
    Looks like the framework is crashing..
    I just noticed this in the crash text you sent.
    xdFZySjlJvJuSyJCrKNFqiOVuiS <<<<---?????
    Assembly Version: 0.0.0.0 <<<<---?????
    Are you able to run this buddy?
    https://www.microsoft.com/en-in/download/details.aspx?id=17851
  19. kjjcard
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    Oh ... Thank you.
    But it is said that the program is already laid out.
    I still have not solved it ...
    My OS is Win 10 pro.
    Hmm ... I do not know what the problem is ...
  20. yobuddy
    51,676Coins
