Bug Surge problem
Discussion in 'SimTools DIY Version' started by evolaco, Jul 27, 2017.
  1. evolaco
    evolaco Member
    Spain
    694Coins
    Hello everyone, I am having very strange problems with the surge, when leaving not stop knocking the chair as if they were bumps, but I have only activated the surge, is something very strange and I just do not understand. I do not have any filter applied to surge
    153,986Coins
    +11,162 / 57 / -2
    Please post pictures of all your settings.
  3. evolaco
    evolaco Member
    Spain
    694Coins
    The other forces deactivate them so that only "surge" is used, if I do not put any filter and in the tuning center to 3 and -3 is moved mad when leaving or circulating in straight line as if they were bumps, simtools sends fast signals up and down Without sense, I have to put much softened and dead zone to remove part of those movements but I lose sharpness of forces in the changes of march
  4. yobuddy
    51,563Coins
    @evolaco Post us some screen shots of you axis and interface assignments please buddy.
    Well figure it out man!
  5. evolaco
    evolaco Member
    Spain
    694Coins
    I am still starting to adjust and I only use the surge because it is the one that gives me problems, in this video it is perfectly my problem, the video is not mine, the game sends signals to surge that do not make sense, you must have the same problem do not? How to solve it?
    153,986Coins
    +11,162 / 57 / -2
    Both @yobuddy and I have asked you to post pictures of all your settings @evolaco, it is very hard to offer help without them and someone elses video is no substitue for them.
  7. evolaco
    evolaco Member
    Spain
    694Coins
    This is only tests, do not do much, I used f1 to capture the limits and 100% in surge to feel them to the maximum, only use arises now
  8. evolaco
    evolaco Member
    Spain
    694Coins
    some help? The problem is that Corsican assetto sends vibrations in the nonsense surge, or I have dissimilated with the smoothing but I lose sensations in the gearshift
    153,986Coins
    +11,162 / 57 / -2
