Simple application to analyze the axis setting
Discussion in 'Miscellaneous' started by perdixero, Jun 18, 2017.
  1. perdixero
    perdixero Member
    Argentina
    793Coins
    Hello @ paulopsx2.
    Make sure you configure the interface correctly.
  2. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    Thanks !! Now works !
  3. yobuddy
    51,544Coins
    @Pit, will you sticky this too?
    thx man!
    153,938Coins
    +11,158 / 57 / -2
  5. yobuddy
    51,544Coins
  6. Pit
    30,510Coins
    Your wish is my command.
  7. yobuddy
    51,544Coins
  8. Alexander Asner
    Alexander Asner New Member
    271Coins
    3DOF, SCN5, SCN6
    I am quite new to this. I bought a Pro-Simu based DIY rig and will get it next week. In the meantime I try to understand the software. I thought this app would be excellent to try some things. However I can't seem to get it to work. I have done all the settings as in the picture. I have also assigned the axis and installed the iracing plugin and patched the software. The virtual axis' in the Game Engine works just fine. The app seems to get the appropriate input as well as I can see A,B,C in the data field. However neither the bars nor the seat are moving. Any idea what I could be doing wrong? Unbenannt.PNG
    153,938Coins
    +11,158 / 57 / -2
    You seem to have accidentally added an additional ) just before the final closing ] in the Interface Settings, try deleting it and see if that makes any difference.
  10. Alexander Asner
    271Coins
    3DOF, SCN5, SCN6
    Well, what can I say? I am a dummy. That was the error. Everything works as expected now. All the axis move as they should which means I have understood the basics of the software. Can't wait to get my rig and see those actuators moving. Kind of a childhood dream coming true. Thanks so much, Noorbeast.
    153,938Coins
    +11,158 / 57 / -2
    You are not a dummy, you have just learned something you are unlikely to forget ;)
  12. Tony168
    Tony168 New Member
    - 22Coins
    這是一個很棒的模擬器。在開始製作硬件之前,我可以學習如何使用該軟件。我仍在嘗試連接到LFS。我是否需要更改PORT值(5002)的設置?
  13. Tony168
    Tony168 New Member
    - 22Coins
    This is a great simulator. I can learn how to use the software before I start making hardware. I am still trying to connect to LFS. Do I need to change the setting of PORT value (5002)?
  14. Metaverum
    Metaverum Member Gold Contributor
    146Coins
    2DOF, 3DOF
    I can't seem to get it to work either.. :(
    I will upload my axis and interface settings, my IPs and ports are the same across the board but it doesn't work. Not sure what the problem is.
    UPDATE: I managed to fix it by doing the following: unpatch the game, finish a race, exit the game and patch again. Now it works, thanks to yobuddy, saw this fix in another thread.
    https://www.xsimulator.net/community/threads/lfs-not-outputing-data.12592/
      186.7 KB
      878
      182.9 KB
      835
      38.3 KB
      847
  15. Pitchoun511
    Pitchoun511 Member Gold Contributor
    Perpignan
    387Coins
    this tester is amazing!
    I try to devellop a game with Unity and simtool, it will help me to test without my simulator!
    Thank you!
  16. Arsalan Khan
    Arsalan Khan New Member
    - 4Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF, 6DOF
    Hi, I am a new enthusiast, I want to try your program but it keeps crashing for me whenever I press start.
