3 dof platform what you think(Elastic-Actuated Delta Robot)
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by misoswan, Aug 5, 2017.
  1. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    3 dof or more?
  2. SeatTime
    28,320Coins
    Cool looking and a novel idea :), but way too complex for what it is - a standard stewart platform would be allot easier to build/drive and give a true 6DOF.
  3. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,761Coins
    DC motor, Arduino
    I do not understand, it's very similar to my tutorials which has already been built with quite a few copies:
    https://www.xsimulator.net/communit...lator-building-tutorial-3dof-heave-axis.9249/
    Three ball joints suply, split the connecting rods and lengthen them ...
    The difficulties seems easy to overcome ...;)
  4. SeatTime
    28,320Coins
    True, builds like yours have been around for a long time - maybe this variant just looks complex - inverted delta 3D printer o_O . Your build although does not have the high angles and required leverage as displayed in the video.
  5. Zed
    USA
    5,841Coins
    It also looks like it can't yaw? Maybe I'm missing something there.
  6. value1
    14,896Coins
    Quote from the youtube comment: "This is a 3-DOF Delta parallel robot actuated by series elastic actuators, designed and built by an undergraduate team at Northwestern in 2017 as part of their ME 398 senior capstone design course. Here it demonstrates motion of the platform in the three actuated directions, x, y, and z."
  7. momoclic
    Retraité
    Nantes - France
    2,761Coins
    DC motor, Arduino
    If it can not make the yaw effect in the strict sense (pivoting on the axis), it can make lateral and longitudinal displacements.
    And I do not see how this would not be possible by modifying the elements cited in my tutorial.
    Of course the position of the crank is to review as well as the elements mentioned above but it is quite achievable and fairly simple (for me ...);)
  8. Rob Povey
    Rob Povey New Member
    Redmond USA
    332Coins
    These types of mechanisms are used in high speed pick and place machines, and are the precursors to the mechanisms commonly used in delta printers.
    The mechanics guarantee they can't roll pitch or yaw.
    If you want to introduce a 4th axis, you'd need to introduce an extra actuator somewhere.
  9. momoclic
    Retraité
    Nantes - France
    2,761Coins
    DC motor, Arduino
    Certainly I did not push the reflection, but nothing prevents to make a simulator.
    The only effect that can not be reproduced will be the lace effect (pivoting on the central axis).
    Compared to a 3DOF we gain the lateral and longitudinal movements.
    And without the need for additional power, perhaps a little extra power ...
  10. SeatTime
    28,320Coins
    If you scale this up to put a human on it then you have quite long levers off the motors (more torque required) driving a small platform (more torque required) - I therefore would expect quite a bit more power/torque would be required from the motors in comparison to your build to move the same load at a similar speed.
  11. momoclic
    Retraité
    Nantes - France
    2,761Coins
    DC motor, Arduino
    Given that the cranks (lever) will be longer this will accelerate the travel speeds,
    Moreover the possible angle of rotation is less than 90 ° then perhaps it will be possible to reduce the speed of rotation, thus with more reduction, more torque.
    There is a small study to be carried out, but a priori no reason it does not work;)
