value1
X-Plane V10 Plugin 2.0.2.0
SimTools game plugin for X-Plane V10
  1. value1
    14,244Coins
    X-Plane Plugin - SimTools game plugin for X-Plane V10
  2. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    Thanks for your good work to produce a lot of plugin !
    I do not know if this plugin is supposed to work with X-Plane 9 but I tried with it and it detects the game well. My problem is that the games do not want to send data to the game engine (on a second PC), it asks me to buy the usb key level 2. I also wonder if there is not some thing to set the UDP port of X-Plane?
    Eric
  3. yobuddy
    51,563Coins
    The X-Plane plugin that's available for download is for X-Plane 10.
    The patch was made for version 10 also.
    Simply un-patch your game to return it to normal.
    Since its not a Bug, will you remove the Bug status.
    Thanks man!
  4. value1
    14,244Coins
    I believe it should be possible to tweak X-Plane 9 manually to get data into SimTools. I'll have a look tonight.
    T.
  5. value1
    14,244Coins
  6. value1
    14,244Coins
    Hi @ericRacer
    I don't have X-Plane V9 available but let's try. Use the corresponding menus with your X-Plane V9:
    • Patch the game with GameManager.
    • Start GameEngine and X-Plane
    • Select Settings - Data Input & Output in X-Plane
    • Check the box Enable Internet and select the following 3 entries (and only these!)
    ▫ Mach, VVI, G-load
    ▫ pitch, roll, headings
    ▫ loc, vel, dist traveled
    They are possibly not located in the same slots as in V10. This is not important. What is important though, is the order in which these values are (Mach first, loc last). If this is not the case, please tell me.
    On the bottom right enter 100 as UDP rate.
    Close the Data Input & Output window.
    • Select Settings - Net Connections
    • Check IP of data receiver.
    Enter the IP address of your 2nd PC (where GameEngine is running) or 127.0.0.1 if you're running SimTools with a single PC setup.
    Enter 4123 as port.
    Close the Net Connections window again.
    If this works fine, you should now receive data in the GameEngine Tuning Window.
    If not, please let me know and we have to dig a little deeper.
    T.
  7. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    thank you, you are the man ! :thumbs
    It works fine (the communication !) i receive the data on my second PC ! :D
  8. Abdul Hameed
    Abdul Hameed New Member
    437Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SCN6, SimAxe, Arduino, JRK, Joyrider, SimforceGT, Motion platform, 4DOF
    X-plane 10 Sim Tool 2.0.0 not working , when the game stats both motors just move to center then no response
  9. value1
    14,244Coins
  10. silmar
    silmar New Member
    - 78Coins
    I'm thinking of changing the FSX X-PLANE10, just swap the plug will be right
  11. Igor1357
    Igor1357 Member
    Kramatorsk Ukraine
    314Coins
    I wonder whether it is possible to connect the sim tools for feedback wheel.
  12. value1
    14,244Coins
    Yes, the plugin works with x-plane 10.25
  13. baykah
    baykah Active Member
    Toulouse - France
    414Coins
    Is it working with xplane 11 ?
  14. value1
    14,244Coins
  15. baykah
    Toulouse - France
    414Coins
    Great thanks !
  16. baykah
    Toulouse - France
    414Coins
    Did you implemented the extra 1 & 2 for roll and pitch like you did in FSX ?
    I mean, I tried to play with washout simtool function for roll and pitch but I cannot say for sure how it feels ..
  17. Emiliano Vega
    Emiliano Vega New Member
    Argentina
    161Coins
    HI @value1
    I am new with this... I downloaded your plugin... I drag and drop into the plugin installer... but the Xplane doesn t appear at GameManager... Probably I skipped something...
    any help will be appreciated!
    Emiliano
  18. yobuddy
    51,563Coins
  19. Emiliano Vega
    Argentina
    161Coins
  20. Floydpr
    Floydpr Member Gold Contributor
    Okc
    - 33Coins
    Hi to all, is this plugin work with the New X plane 11?
