Question How to change start position in Simtool.
Discussion in 'SimTools DIY Version' started by Schopfer, Aug 9, 2017.
  1. Schopfer
    Schopfer Member
    Thailand
    86Coins
    1.When I start output testing in simtools the position is change 45 degree from middle.
    2. axis test 0-3% move fast 4%-55% is slow and then 56% it switch backward and forward
  2. yobuddy
    51,564Coins
    I'm not sure I understand what your asking buddy?
    153,986Coins
    +11,162 / 57 / -2
  4. Zed
    USA
    5,845Coins
    Thanks for that @noorbeast! Was looking for how to do that!
  5. Schopfer
    Schopfer Member
    Thailand
    86Coins
    do not different. I think it may have been caused by a potentiometer
      682.5 KB
      839
  6. Schopfer
    Schopfer Member
    Thailand
    86Coins
    now position is in the middle. but it still jerk.
    I uncertain about motor or potentiometer.
    PS. I use wiring + - to motor in mini servo 9g. I will try on wiper motor soon.:)
    153,986Coins
    +11,162 / 57 / -2
  8. Schopfer
    Schopfer Member
    Thailand
    86Coins
    it't jerk when pwmmax >50 in SMC3
    it's varied by pwmmax.
  9. yobuddy
    51,564Coins
    Please try this and see if it fixes your problem buddy,
  10. Schopfer
    Schopfer Member
    Thailand
    86Coins
    I find a problem.It should be wiring potentiometer is not fit.
    I has a question. my arduino pin 3 and pin 10 is not working. "SMC3 CODE" can change Pin number" in
    const int ENApin1 =2; // ENA output pin for Motor H-Bridge 1 (ie PortD bit position)
    const int ENBpin1 =6; // ENB output pin for Motor H-Bridge 1 (ie PortD bit position)Switch from ENBpin3
    const int ENApin2 =4; // ENA output pin for Motor H-Bridge 2 (ie PortD bit position)
    const int ENBpin2 =5; // ENB output pin for Motor H-Bridge 2 (ie PortD bit position)
    const int ENApin3 =3; // ENA output pin for Motor H-Bridge 3 (ie PortD bit position)NOT USE
    const int ENBpin3 =7; // ENB output pin for Motor H-Bridge 3 (ie PortD bit position) NOT USE
    const int PWMpin1 =9; // PWM output pin for Motor 1
    const int PWMpin2 =11; // PWM output pin for Motor 2 Switch from PWMpin3
    const int PWMpin3 =10; // PWM output pin for Motor 3 NOT USE
    Can I do this?
  11. Piotr
    Piotr New Member
    99Coins
    Thanks!! It help for jitter and wrong starting position in SimTool. I was trying to fix this problem long time.
  12. ZO-3NISHIKAPPA
    ZO-3NISHIKAPPA New Member Gold Contributor
    - 24Coins
    3DOF, Arduino
    I'm also having trouble with the same symptoms.
    Is the solution to change the potentiometer?
  13. nnelsonn
    nnelsonn New Member
    307Coins
    3DOF, DC motor
    wich arduino board do you use?
