Looking into a brushless setup
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by matthew loomis, Aug 9, 2017.
  1. matthew loomis
    matthew loomis Member
    rochester,ny
    603Coins
    Looking into motors and such started thinking about brushless. Have some experience from my rc hobby. Brushless has been a revolution everywhere else so I looked at this
    And maybe control with this or similar
    Any reason this would be extra hard?
  2. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    You need to source reversible motor controllers. Also I'm not sure if anyone has written code to talk to the motor controller.
    BLDC motors are pretty much stepper motors with fewer steps, as far as I know there is not any mature control package for steppers/BLDC.
  3. matthew loomis
    rochester,ny
    603Coins
    Those are fully reverseable rc controllers and use servo code to operate. Lots of servo controlled ard projects
  4. ferslash
    ferslash Active Member
    4,798Coins
    if the motor you selected would do the job, what is the price of the motor and the driver? (if it is in your info sorry i did not see it)
    :popcorn
  5. matthew loomis
    rochester,ny
    603Coins
    The rc speed controller runs about $120 so same range as a sabertooth. Having trouble on pricing motors but around the 100-200 range so comparable there as well.
    I want to do a 3dof so I need pretty good torque numbers
  6. Alexey
    Adelaide, Australia
    8,066Coins
    Sounds pretty straight forward then. Couple that with a gearbox and you should have a pretty strong setup.
  7. matthew loomis
    rochester,ny
    603Coins
  8. matthew loomis
    rochester,ny
    603Coins
    Power scooter motors are 4nm for $125
  9. SeatTime
    I've seen a few DC brushless projects pop up then - nothing heard ... Just takes someone to put in the time/money.
  10. ferslash
    4,798Coins
    how many motors does talon driver actually controls?
    if they countrol only one, maybe in terms of money the scooters motors are a better option... the interesting thing about the other motors should be the size, maybe they are cheap to send on the mail..
    fer
  11. DEADBEEF
    DEADBEEF New Member
    N/A
    370Coins
    ODrive may be worth a look for this sort of thing once they've matured a bit.
    They're aiming for an open source BLDC controller board which can controll two motors, handle encoder feedback, and work up to 100A peak current. If it all comes off they sound perfect for controlling motion sims.
  12. matthew loomis
    rochester,ny
    603Coins
    I have found some bldc stuff that will take pwm input. It's all expensive. I'm worried about speed (latency) using rc servo controllers. Brushless Electric moped motors look close, and cheep. Trying to find solid torque required numbers is tough, different for each design. 1-3 hp motors seem to do the trick, getting that at 24v is tough. 48 not so tough
  13. auryza
    auryza Active Member
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Hello ,
    I'm working on stepper motion control, things looks promising . ;)
    With this small 8Nm motor, and what you see in picture i can lift around 20 kg.
    And some video:
  14. matthew loomis
    rochester,ny
    603Coins
    I've been looking at hobby stuff. These motors output over 3nm for under $100
  15. pmvcda
    15,479Coins
    I made a topic about my 6DOF build with brushless motors.
    I can share what I'm using:
    Motor:
    Nanotec DB59C024035-A (brushless).
    Bought at Farnell (http://pt.farnell.com/nanotec/db59c024035-a/bldc-motor-24vdc-4500rpm/dp/2507576
    Specs: http://en.nanotec.com/fileadmin/files/Datenblaetter/BLDC/DB59/DB59C024035-A.pdf
    Right now they are around 99€ each one.
    They are rated 3500rpm and 0,6Nm (4500 rpm 1,8Nm peak)
    For a SFU1605 (ball screw), thats 16mm diameter with 5mm travel on each turn we can have for rated values:
    3500rpm => 290mm/s of travel
    0,6Nm => 372N = 38Kg of lift
    Motor drivers (one for each motor):
    ACT Motor BLDC-8015A
    Bought on ebay (http://www.ebay.co.uk/itm/EU-UK-Brushless-DC-Motor-Driver-BLDC-8015A-18-80V-Nema17-to-Nema23-Wantai-/282017543495?hash=item41a98e3547:g:56oAAOSwubRXHvie).
    Specs: http://www.wantmotor.com/product/8015a.html
    They cost around 40€ each.
    This with an Arduino, works really well and we can go up to 6 motors with one Arduino.
    My schematic:
  16. pmvcda
    15,479Coins
    Missed one image (can't edit the above post, gives error)
  17. Zennix
    Zennix New Member Gold Contributor
    Bayern
    66Coins
    I'm new in this business. Thinking in the same direction using cheap brushless motors and drivers.
    Some time ago, I build quadrocopters with brushless motors that can change the direction of the propellers to fly upside down.
    I remember a project where somebody has written a firmware for several ESC (brushless motor drivers).
    Sorry I'm not allowed to post the link. Just search for Simonk.
    This software is able to turn the motor in the other direction. The input for the ESCs is PWM.
    In the list you will find the supported drivers and how to flash that.
    Greetings / Zennix
