Question SimTools 2.2?
Discussion in 'SimTools Pro & Entertainment Version' started by Zed, Aug 12, 2017.
  1. Zed
    USA
    5,845Coins
  2. yobuddy
    51,563Coins
    v2.2 will be a big release, as I have allot of stuff to put out.
    This is not a complete list I'm sure.
    - GameDash will support separate edits per interface, allowing to run 3 completely different DashBoards at the same time.
    - Video Ride Player Update and GUI fixes.
    - GameVibe beta will be released with 2.2.
    - Lots of stuff fixed, added and polished in both GameManager and GameEngine.
    - The interface API will be fully released (And the example files will get posted)
    - SimTools launcher (one click launch all of SimTools launcher) will get posted.
    - The SCN interface will now support 2 scn's per interface.
    I'm sure there is more, I just have not had enough coffee yet this morning lol.
    btw, No, 2.0 update will not break plugin compatibility.
    I'm pretty sure @value1 would have my head if I ever changed it again. lol
    • Like Like x 5
    • Informative Informative x 3
  3. Zed
    USA
    5,845Coins
    Wow! Nice, nice, nice!
    Thanks and looking forward to it!
  4. Eddy Baldon
    Eddy Baldon New Member Gold Contributor
    235Coins
    Btw -not a complete list...
    Will come up an option in Tuning Center for saving different Profiles? Thx...
    153,986Coins
    +11,162 / 57 / -2
    While it is not what you are asking for you can do that to a degree already in a different way.
    When you are satisfied with the generic motion profile and Tuning Centre values you can then refine it even further by creating specific car/track profiles in the Profile Editor, located in the SimTools Game Manager. Copy the Default Profile in Profile Editor under the Editor tab, name the copy by the Car/Track then use the sliders in the Editor to further tweak the settings for each axis/force.
  6. Eddy Baldon
    235Coins
    Thx, I know. But tweaking a midrange value with sliders is not the same. In Tuningcenter the clippingfree max values can be detected very exactly and without any risk of give away resolution. Moving sliders is something like searching in the dark. There is no reason, why in Tuningcenter isn't a "Save as...".
  7. Neman Ahmed
    Neman Ahmed Member
    Automation Engineer
    Karachi, Pakistan
    163Coins
    3DOF, AC motor, Arduino, Motion platform, 6DOF
    Keep up the good work
  8. Eddy Baldon
    235Coins
    No question. A lot of work and very well done. Thx, thx, thx.
    But, with a little sarcasm, in my experience one of the main features of nearly all devs is, to be largely immune to feedback. Present company excluded... hoping... ;-)
    153,986Coins
    +11,162 / 57 / -2
    Feedback is fine but keep in mind most devs have a development path and a user request, even a good one, will always be considered relevant to pending and competing priorities of the road map.
  10. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    In my time here yobuddy has been active in all software conversations and many more. He is as tuned in to user requests as any dev could be at the same time putting in enormous effort into an amazing product. Monetization seems to be the last priority with basically giving away the software to this community.
    I am extremely grateful for the hard work and dedication of yobuddy and for the fantastic community built around his software.
    THANK YOU
    • Agree Agree x 3
  11. yobuddy
    51,563Coins
    I'll try to explain a bit why it works this way.
    It will either make sense, or we can chat about how it could be better.
    Making SimTools the best it can be is the goal overall!
    Using the Sliders will not give up any and resolution or accuracy.
    You see, it just scales your Max/Min settings into range for the new car.
    (up to 50% bigger numbers or 50% smaller numbers)
    Even when you initially capture settings for a game, they don't really mean allot, until you take a ride with the settings.
    So, in a way, your butt tells you what is correct for the car
    When you switch cars, if you have to much surge say, you just slide it into scale for the new car.
    (In this case turning it down a bit.)
    You can adjust this even while you are racing. (remote profiler)
    Letting your butt tell you when you have it correct.
    Its just what I found that works pretty easily and keeps the user racing.
    Instead of constantly making new Max/Min settings all the time.
    And in the end, it does pretty much the same thing.
    Hope that help explain my reasoning behind how it was done this way.
    Take care,
  12. Eddy Baldon
    235Coins
    Dear yobuddy.
    Thx a lot for your statement and your time for development. First of all: Great work! Thx again!
    I´m a litte perfectionist not to say pedant. Your way, moving sliders until the seat of the pants feel ( in German: Popometer ) say ok, is usable. No question. But it´s not the only or imho the perfekt way. It´s good for users who don´t care about details and technics. Easy doing, easy gaming.
    According to my understanding the captured levels are more than important. It´s the identical to the FFB levels. What you geht from car / Track must be the optimal level between 0 and 100. The less you loose information the more there is signal clipping. Perfekt input is the base of all. This input the software has to interpret for a good output. If the input is not perfect, the output can´t be better.
    Cause of tons of possible car / track input combinations, the input levels needs need a possibility to save optimal profiles. Than outputsliders became unimportant.
    Stay ccol...
    Eddy
  13. yobuddy
    51,563Coins
    Whatup @Eddy Baldon,
    Max/Min settings are not that technical thou.
    Let's take roll for example.
    We know that the game should give us 180deg to -180deg (making a full circle).
    We capture settings for roll and get 20 & -20 for Max/Min.
    This means when the game sends out a 20, Roll = 100% for that direction, and -100% when it sends -20 in the other.
    This also means that any degrees above or below these settings get ignored for 100% or -100%.
    Then if we use 25 and -25 for the Max/Min numbers, is it wrong?
    Not really, because doing this, the sim will react less to small changes.
    But it will react to output changes up to 25deg now instead of just 20deg.
    So it then comes down to what feel write on the old "Popometer".
    So to me, somehow, it always comes back to the butt. lol :cheers
  14. faco
    faco Faco
    0Coins
    SCN5
    With the purchase of a commercial license in 2.0, are updates included?
  15. faco
    faco Faco
    0Coins
    SCN5
    and what is the release date of version 2.2
  16. noorbeast
    153,986Coins
    +11,162 / 57 / -2
    Yes updates are included.
    When @yobuddy, the SimTools developer, deems it ready.
  17. riton
    riton Active Member
    1,006Coins
    SimVibe will be present with version 2.2 is that?
    My ButtKicker is waiting impatiently!
    this update is planned for which date?
  18. noorbeast
    153,986Coins
    +11,162 / 57 / -2
    Releases are always when the SimTools dev @yobuddy considers there has been adequate advancement, refinement, testing and bug squashing....so releases have been when they are considered ready, rather than to some per-determined schedule.
  19. riton
    riton Active Member
    1,006Coins
    Is it possible to participate in Simvibe tests?
  20. Zed
    USA
    5,845Coins
    Of course! It’s GameVibe that’s the difficult beta to get into... :grin
    • Funny Funny x 5
