Bug SimTools rock on stationary and at low speeds
Discussion in 'SimTools DIY Version' started by wustamariana, Aug 16, 2017.
  1. wustamariana
    wustamariana New Member
    - 284Coins
    As the topic..
    I swing my entire chair as if I was going off the track, just as I start to move some of the steering axles to work properly, but when it stops it starts to tug at the seat again
    I'm sorry for my English
    Settings will send in the evening
  2. yobuddy
    51,531Coins
    Maybe a loose connection on one of the potentiometer?
    Or maybe the game need the Max/Min settings re-captured?
    couple of things to check anyway,
  3. wustamariana
    - 284Coins
    The settings I have are rather good, the 1.3 works fine for me
  4. yobuddy
    51,531Coins
    Do you have 2.1 and 1.3 installed on the same PC?
    They don't work together is all.
    If not, its probably the Max/Min values for the game.
  5. wustamariana
    - 284Coins
    I do not have the same, I've checked and uninstalled everything that min / Max has in different settings
  6. yobuddy
    51,531Coins
    I would suggesting capturing new Min/Max values for the game.
  7. wustamariana
    - 284Coins
    setting
    153,818Coins
    +11,150 / 57 / -2
    Unfortunately that is is not clear enough to read all the settings. Please take a screenshot of each window instead.
  9. wustamariana
    - 284Coins
    Gentlemen ashamed to admit, were misplaced axes. Confused me setting with 1.3.
    Thank you so much for help
      78.5 KB
      643
      219.6 KB
      696
    153,818Coins
    +11,150 / 57 / -2
  11. wustamariana
    - 284Coins
    Now it is good, there are two settings, good and bad
