News Application to compare axis, filters, etc.
Discussion in 'Miscellaneous' started by perdixero, Aug 9, 2017.
  1. perdixero
    perdixero Member
    Argentina
    793Coins
    Hi!
    I have developed a tool that allows compare axes and also allows you to see the difference when using filters.
    I use it for the fine tuning of the movement.
    Attached some screens and below is the .zip file
    App:
    SimTools settings:
    • Like Like x 6
    • Useful Useful x 4
    • Winner Winner x 3
    153,986Coins
    +11,162 / 57 / -2
  3. yobuddy
    51,564Coins
  4. yobuddy
    51,564Coins
    @Pit, will you sticky this ?
    thx man!
  5. axenic
    axenic Member Gold Contributor
    IT engineer
    Brest
    - 17Coins
    Nice work, I will give it a try as soon as I get some time
  6. dualclick76
    dualclick76 Active Member
    italia
    19Coins
    nice work very interesting
  7. cfischer
    Colorado
    2,807Coins
    This is super nice. How hard would it be to output that to excel? comma separated variable? Id donate for it...
  8. marco balletta
    marco balletta Member
    1,445Coins
    Is there any tutorial for novice to explain how to use it ?
    153,986Coins
    +11,162 / 57 / -2
    The pictures in the first post give the use overview: https://www.xsimulator.net/community/threads/application-to-compare-axis-filters-etc.10695/
    If you alter the Filter settings in SimTools Axis Assignments then you can see the output result in the application graph.
    Filters apply effects to Axis Allocations, such as smoothing or washout: https://www.xsimulator.net/community/threads/playing-with-filters.6564/#post-72565
  10. marco balletta
    1,445Coins
    Is there a tutorial for interpreting these sort of graphs ?
    153,986Coins
    +11,162 / 57 / -2
    No there is no tutorial, nor is one really needed, other than the explanation I just gave, plus the explanation of Filters below, which you will find in the SimTools Manual: https://www.xsimulator.net/community/threads/official-simtools-user-manual.12424/
    Smoothing – Is needed when you are experiencing a jumpy DOF input. The filter works by taking “X” number of last know positions and making an average for the resulting output (mean value). Setting this filter too high may cause some lag in getting to the exact position desired quickly.
    Dead Zone - Is for setting a dead zone around the center of axis. We can eliminate any small twitches we feel from a particular game. Say our Min Max in the tuning center is set to Max 10 Min -10 and we don’t want to feel the jittery motion between Max 3 Min -3 we can set a percent to represent this and take these values away from the equation, resulting in a dead zone on the center of our axis movements.
    Boundary - Is to make sure the single DOF does not use more than X amount of the available axis. In turn letting you have a very sensitive axis while still making sure it doesn’t take over the whole axis and leaves room for other DOF’s.
    (Washout) Gain – This is how much we will react to changes in the input from the game. If your simulator is not moving enough from the output from the game, Increase this value.
    (Washout) Return – This is how fast we try to return to zero after a movement has occurred. If your simulator is not homing (re-centering) fast enough after a movement, Increase this value.
    The Washout Filter is needed when your DOF input fails to return to center after the force is applied to the axis.
    Please be aware that the expectation is that new members will spend some time and effort to gain an understanding from existing information: https://www.xsimulator.net/community/faq/community-etiquette.82/
  12. marco balletta
    1,445Coins
    Ok. Thanks.
    How many people on this forum have practical experience with a 6 dof sim rig ?
  13. noorbeast
    153,986Coins
    +11,162 / 57 / -2
    Quite a few members have practical experience with a 6 dof sim rig, use the Google Custom Seach box toward the top right of the Recent page to find existing 6dof projects.
  14. marco balletta
    1,445Coins
    But none replies sharing their settings for games?
    153,986Coins
    +11,162 / 57 / -2
  16. FrancescoRoberto
    FrancescoRoberto Member
    Italia
    92Coins
    I've tried to start the software "COMPARE AXIS", but I didn't succed. I insert in com port (COM3) and click to start, but I didn't watch any graph.
    May be I wrote in data received the uncorrect datas, I'm going to try again.
    Any suggests?
    Best Regards
  17. FrancescoRoberto
    Italia
    92Coins
    Sorry, but I don't succeed to start the app.
    I write "COM3" in Port cell, then I think to write in "DATA RECEIVED", but it's impossible.
    May you help me?
    Best Regards
  18. tadeusz
    tadeusz New Member
    34Coins
    Hi
    please help
    how to configure the port to be displayed curve.
    Should I set
    Interface Setting
    in GAME ENGINE ?
    best regards
    T.M.
  19. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    Maybe someone can paste pictures with all filters graphs? I think this was be a great explanation for non English users
  20. Nestor Giraldo
    Nestor Giraldo New Member
    Electronics Eng
    Colombia
    147Coins
    Hello! Is usable with v3 beta? Thx
